Release Notes
Version 6.0.1
Improved
  • Improved restoration of state when the app is quit in the background. Improved background task handling.
  • Improved formatting of calendar days in the related panel.
  • Improved date interval formatting, assigned dates now show the weekday.
  • Improved display of time zones in the event and reminder editors.
  • Improved UI for start and end time in event creation/edit popover.
  • Toggling between all-day and timed-events and reminders is now remembered.
  • When creating a new event to be linked to a note, the title of the note is now correctly pre-filled.
  • Added the possibility to exit the preset menu on iPhone for the calendar.
  • Various small UI tweaks and fixes, improved error messaging.
Fixed
  • Fixed an issue where it would not be possible to create an event from the day filter of the related panel.
  • Fixed an issue where the calendar selection popover would incorrectly show disabled calendars as enabled.
  • Fixed an issue where some content would slide underneath the headers.
  • Fixed an issue where all-day events could be shown on the wrong day or over multiple days.
  • Fixed various compatibility issues with the upcoming iOS13 release.
  • Fixed various crashes related to reminders and events
  • Fixed a crash where notes with assigned dates from before 2001 would crash.
Version 7.0 with iOS13 Compatibility, Document Scanning, and Black Theme
New Premium
  • Black theme that takes full advantage of OLED screens
New
  • Scanning of documents via button in keyboard bar (iOS 13)
Improved
  • Agenda now integrates with new iOS 13 dark mode
  • A new note can be created for a reminder via the Related Info panel on right
  • Am existing reminder can be added for the selected note
  • You can now link events by dragging the calendar event onto a note, and vice versa
  • All note actions (eg Mark as On the Agenda) can now be applied to multiple selected notes
  • Better error reporting when working with reminders
  • Calendar event notes with HTML content are now properly handled
  • Switching between projects is now much faster
  • You now tap-and-hold on a project to get a menu of actions, instead of double tapping
  • PDFs can now be shown full-width in the note, with a preview of the first page
  • Clicking the on-the-agenda dot button now shows a menu (macOS)
  • The welcome tour now adapts to dark mode (macOS)
  • Cosmetic improvements for dark mode on macOS
Fixed
  • An agenda link (URL) is now added to reminders (iOS 13 and macOS 10.15)
  • Subtasks of Reminders are now properly handled (iOS 13 and macOS 10.15)
  • Fixed issue with alarm settings on all day calendar events
  • You can again drag-and-drop events in the Related Info panel
  • The Connect to Reminders button was hidden on iPhone SE. It is now visible
  • Linking a note could revert the title to “Untitled”. Fixed
  • The welcome screens now show properly on iOS 13
  • Deleting back to the beginning of a line could cause formatting to change unexpectedly. Fixed
  • Layout is no longer messed up if you rotate the screen on launch
  • Appearance of tags, people, and inline attachments is now improved on iOS 13
  • The Documents folder is no longer visible in the Files app. (It was there by accident)
  • Tap-and-hold on the icon of a tag or person will no longer show a menu (iOS 13)
  • The x-success URL is now properly handled on successful requests for an x-callback URL
  • More stable undo/redo
  • Fixed issues with deletion of emoji and other unicode characters (eg Asian languages)
  • Fixed an issue where the sign in sheet for the Agenda Community would remain on screen
Introducing integration with iOS13’s system wide dark mode, and the new document scanner interface.
Version 7.0.1
Improved
  • The Welcome Tour now adapts to dark mode
Fixed
  • Deleting unicode characters like emoji and Asian language characters now works properly
  • Sign in to the Agenda Community now works again
  • Sync stability improvements
  • Undo/redo is more robust
  • PDFs now can display as full-width previews, instead of just thumbnails
  • Fixed issue where light theme could be used instead of the selected black theme
Version 7.0.2
Improved
  • Speed of handling attachments in notes is improved
Fixed
  • Tapping checkboxes was difficult in iOS 13.1. Fixed
  • Showing the attachment popover menu was difficult in iOS 13.1. Fixed
  • Large PDFs could cause crashes. Fixed
  • Haptic feedback is no longer triggered by orientation changes on iOS 13.1
Version 8.0 with Apple Pencil support on iPadOS
New Premium
  • Add a drawing, handwritten notes, or highlights to the images in your notes.
New
  • Drawing and handwriting with Pencil to create new image attachments.
Fixed
  • Autocorrect was causing unnecessary capitalisation, this is fixed.
  • Tap and hold on a link is now working again.
  • Keyboard bar menus no stay open more often when device changes orientation.
Introducing Apple pencil support on iPadOS 13.1 and higher.
Version 8.0.1
Fixed
  • Links should not open when one is tapped during scrolling.
  • Fixed crash due to autocomplete.
  • Drawing colors on annotations now do not change when switched to dark mode.
  • Stability improvements for sync.
Version 8.0.2
Improved
  • The canvas for drawing changes size dynamically to allow for drawing across multiple pages, and allows scrolling with two fingers.
Fixed
  • The area for tapping ‘live’ text items (eg links, tags, attachments) is now reduced so it doesn’t overlap other content.
  • Tapping of ‘live’ items like links and attachments during scrolling should not trigger them to open.
  • Adding of links works again.
  • Some cases where the insert popover would disappear unnecessarily when lifting the device have been fixed.
  • The drawing tools now show the correct colors when annotating an image in dark mode.
  • Fixed previewing of files with forward slashes (/) in the name.
  • Fixed some problems with wrong colors showing after switching between light and dark mode.
Version 9.0 with Sidebar reordering, Bin, Subcategories, and Archives
New Premium
  • Archive completed projects to keep your Sidebar clean.
  • Create Subcategories in the Sidebar to help organise your projects.
  • Pin notes as footnotes to the bottom of your project.
New
  • Manually reorder the projects and categories in the Sidebar.
  • Move notes and projects to the Bin in the Sidebar before permanently deleting them.
  • Get more information about your projects and notes, like when they were created and edited, and how many notes, words, and characters they contain.
  • Added x-callback-urls for opening smart overviews and triggering searches
  • Now suggesting a project for a linked event if the event is part of a series we previously linked a note to
  • When linking to an event in a recurring series we now automatically insert a link to the previous notes
Improved
  • It’s now possible to create Agenda links to smart overviews
  • Directly insert links to other notes and create web links from the plus menu on iOS and iPadOS
  • When using an Apple pencil to draw, input from hand and fingers is automatically rejected. This can be reverted in the Agenda preferences if both pencil and hand drawing is desired.
  • Drawings are now opened again when tapped without the need to explicitly tap Edit in the popover menu, allowing you to continue to write notes for example
  • Drawings are now automatically inserted and saved when leaving or terminating Agenda
  • Drawings now have some padding at the edges, rather than going right to the edge of the image
  • If the “Assign today to new notes” option is enabled, the default title will also be set accordingly
  • Added a "No projects” placeholder for empty categories
  • Added the ability to share an Agenda link
  • Added the collapse/expand option to dot menu on iOS and iPadOS
  • Added copy as HTML and Agenda link keyboard shortcuts to iOS and iPadOS
  • Added actions to move a note up and down, and to beginning or end of a project, including the respective keyboard shortcuts on iOS and iPadOS
  • Agenda now remembers the closed/open state of Sidebar and Inspector when the app is closed on iOS and iPadOS
  • Hitting return in the save as overview and new category panels now commits the changes on iOS and iPadOS
  • You can now shift/command select multiple smart overviews on macOS
  • When scheduling events and reminders suggested times are now rounded to 15 minutes
  • Improved sidebar selection heuristics upon deletion and archiving projects
  • Improved visibility of some category colors
  • Improved suggested name for search overview of tags
  • Improved collapsing and expanding of categories in the sidebar
  • The Link To menu now shows recently edited notes
  • It is now possible to select/deselect all enabled calendars in the preferences by holding the option or command key while clicking one of the calendars.
  • Now making sure the email and password fields scroll up to prevent them from getting behind the keyboard on iOS and iPadOS
  • Allow suppression on iOS of the question whether to pin or make footnote after it has been asked 3 times
  • The limit on PDF size before they no longer show full width has been increased on iOS and iPadOS
  • Updated the premium features gallery and tutorials to mention both iOS and iPadOS
  • More regular undo snapshots are taken, to prevent large blocks being undone
  • When using the \remind shortcut longer note titles are supported
  • iCloud sync has performance and stability improvements
  • Transparent images now have a transparent background in the text editor, instead of always a white background (PDFs still have a white background)
  • Added a Dark mode version of the introduction movie
  • Hover delays in sidebar and inspector are now equal to tooltips on macOS
  • Added possibly to supress warning when deleting smart overviews and categories
  • Related sections now also show notes linked to the same series of events
  • Accent colors in preferences on iOS now are ordered the same as in the system preferences on macOS
  • Improved a performance when editing and viewing larger notes that could freeze the app
Fixed
  • Agenda links now keep working when moving notes between projects
  • The calendar and reminder editing panels can no longer go offscreen, which would make it hard to tap done (iOS and iPadOS).
  • Tapping close to URLs and Attachments no longer triggers their actions and properly selects the text. This also fixes the issue where it was difficult to move the selection to the end of a note with an attachment or link (iOS and iPadOS).
  • When using Agenda in split screen the note content should no longer go offscreen. This also fixed the issue where thee project title header would not be laid out correctly directly after starting the app (iOS and iPadOS).
  • Sharing of markdown and plain text note content to shortcuts should now work on iOS13
  • Fixed an issue where hitting delete while typing a tag or reminder would already create them
  • Fixed an issue where the tutorial would have black text when run on systems set to dark mode
  • Fixed an issue where reminders were hard to tap on iOS13
  • Fixed an issue where reminders were not getting a proper link and were not scheduled immediately, leaving the link to the reminder unconnected
  • Fixed an issue where switching between light and dark mode would not work correctly (iOS and iPadOS)
  • Fixed an issue where editing a link would not work unless text was selected (iOS and iPadOS)
  • Fixed an issue when creating a new category where the panel was not shifting up until touched (iOS and iPadOS)
  • Fixed a crash when selecting a project in the sidebar after rotating the device (iOS and iPadOS)
  • Fixed invisible swipe action icons (iOS and iPadOS)
  • More reliable display of the dots in the sidebar (iOS and iPadOS)
  • Changes to selected calendars should now persist after scrolling the list of enabled calendars
  • Added extra safety check before inserting Agenda links in exchange calendar events
  • When cancelling a move of notes to top or bottom on iOS the gray placeholders are now removed
  • Removed the Show in Reminders option which no longer works on iOS13
  • Fixes to sync which could cause changes to not transfer from iOS to other devices in rare cases
  • Fixed an issue where moving a drawing to a different project could cause it not to display anymore
  • Improved look of scrollers in dark mode for legacy scroller setting (macOS)
  • Pasting of links into the link popover now works better
  • Prevent a crash when accessing the tableview menu (macOS)
  • Fixed a slow memory leak that could accumulate if the app runs for several days
  • Fixed the share sheet from the sidebar on iOS, better agenda link creation for sidebar items
  • Fixed a number of sync issues.
  • Fixed the x-callback-url handling of on-the-agenda, today, and open-search
  • Fixed a deadlock upon an incoming project deletion through sync
  • Fixed an issue where under rare circumstances due to sync the same project could appear twice in the sidebar
  • Fixed the issue of hard to read placeholder colors in text and searchfields under dark mode (macOS)
  • No longer lazily load the empty screen to prevent flashes on macOS
Archive project that you no longer need or have concluded, keeping them at hand without cluttering the Sidebar.
Version 9.1
New
  • Added the create-project x-callback-url to allow the creation of new projects.
Improved
  • Showing the “Pencil Islands” empty project/search results placeholder no longer causes the Agenda window to blink. (macOS)
  • The table of contents now show the category where appropriate.
  • The Other Projects entry now correctly hides when it has no longer any visible items.
  • Upon linking to an event the note now receives the title of the event when appropriate.
  • The community forum now supports dark mode.
  • When right-clicking a note the contextual menu should no longer show twice (macOS).
  • The delete button while editing an event or reminder is only shown when the calendar is editable.
  • Various performance improvements.
  • Images and drawings no longer have a height limit, so they should display full width in all cases.
  • Small user interface tweaks.
Fixed
  • Copy as Agenda URL now works correctly for projects and categories (iOS)
  • Navigating using the arrow keys is now much faster.
  • Note titles are no longer editable while a note is collapsed.
  • Fixed an issue where sync could get stalled due to excessive resource usage.
  • Fixed an issue where part of the UI would stay white when switching from light to dark mode.
  • Fixed a crash upon mark down import.
  • Fixed some crashes during drag and drop of projects and categories.
  • Fixed an issue where watching the welcome tour on iPhone from the Agenda preferences could leave the window in an odd state. (iOS)
  • Fixed a typo in the bin placeholder text when empty.
  • Fixed issues with text selection changing when a note is updated by a background sync.
Version 9.1.1
Improved
  • Archived notes no longer appear in overviews.
Fixed
  • Fixed some rare sync issues which could cause some text loss.
  • Fixed issue causing unnecessary saving/syncing of data.
Version 9.1.2
Improved
  • Reduced memory use
Fixed
  • Memory use would grow if the app was kept open several days, this is now fixed (macOS).
  • The keyboard accessory bar will not be cropped in landscape on some iPhone models.
  • Limits have been added to the size of drawings with Apple Pencil to prevent excessive image size.
Version 9.1.3
Improved
  • Less memory usage due to better handling of images
  • The Get All Features button will never be shown if you have previously purchased
  • When drawing or handwriting, regular saves are now made to prevent major data loss should a crash occur
Fixed
  • Addressed a rare issue where data loss could occur during sync
  • When logging in to the agenda account on iOS and iPadOS from the preferences, the system could instead of auto-completing the password insert a newly generated password, causing log in to fail. This is now fixed.
Version 9.2
New
Improved
  • Sign in with Apple for Agenda Accounts (App Store-only)
  • Better crash reporting on macOS
  • There is now a button to clear the current value when linking dates and events
  • Added JPEG compression for scanned images in PDFs on iOS and iPadOS
  • Improved layout of the Agenda account login UI
  • Added more quick reschedule options
Fixed
  • Fixed problematic handling of time zones for events and reminders
  • Search highlights would sometimes not be removed properly. Now they are
  • Various text editor bug fixes, including editing of tags
  • Various crashes resolved
Help us translate Agenda to your favourite language by signing up as translator!
Version 9.2.1
New
  • Use the Add Sketch menu item to insert drawings you make directly on iPad or iPhone
Fixed
  • Fixed duplicate notes created when dragging to other projects
Version 9.3
New
  • A indicator now appears (on macOS in the top right, on iOS/iPadOS in the right panel) to show when Agenda is actively syncing
Improved
  • Now scrolls more nicely to a newly linked event
  • Added an icon to the new project option in the + menu
  • If a checklist item has a reminder, checking off the reminder will now automatically check off the item as well
  • Better handling of 24hr format when adding events
  • Return characters are now removed when pasting text into the title field of a note
  • There is now an Empty Bin menu item on iOS/iPadOS
  • Notes exported as rich text are now exported in the current sort order on screen
  • Adding a note to the “On the Agenda” section will now put it on-the-agenda, regardless of the Agenda Settings
  • You can now use CMD-P for printing on iOS/iPadOS
  • It is now possible to suppress the warning about moving a note to the bin on iOS
  • If you choose Dropbox sync on iOS/iPadOS, you are now warned if the Dropbox app is not installed
Fixed
  • Move down command will no longer ask to make footnote when moving to the second last position
  • Fixed a crash when setting a note on-the-agenda via keyboard shortcuts
  • Behavior of calendar in the related pane (right) is smoother, and less “jumpy”
  • Selecting a date on the calendar was not always working. Fixed
  • The calendar now reloads properly when first authorizing it
  • Languages with special keyboards (eg Mandarin Chinese) could sometimes accept half-entered text when the user waits for 10s or so. This is now fixed so that it will not commit incomplete text
  • On iPad, with Agenda in split screen mode, and very narrow, the overlay for some languages (eg Chinese) would be cropped by the screen, so you couldn’t pick the correct value. This is fixed
  • The name “Untitled category” is no longer used for new projects on iOS
  • Some events could appear with the wrong duration. Fixed
  • The related panel now updates faster when a reminder is edited or deleted
  • Fixed some drawing glitches in the related panel on iPhone
  • Feature descriptions are no longer cut off
  • Using the append-to-note URL scheme could sometimes prepend instead. Fixed
  • The tooltip for deleting a category is now correct
  • Fixed a cancel button with the wrong label
  • Some fixes to editing preformatted blocks
Version 9.3.1
Fixed
  • Fixed issue where empty lines could change into checklist items or other styles
  • A new note could sometimes appear with a style other than body text. This is fixed
  • Layout issues that appear when quickly moving notes have been fixed. These could cause cropping of text at the top or bottom
Version 9.3.2
Fixed
  • Fixed crash that occurred when launching on macOS 10.12
  • Update of selection when inserting links is now fixed
  • Corrected text on one of the “Contact Us” buttons
Version 10.0 with Sharing Extension, Templates, French, German, Spanish and Chinese translations
New Premium Feature
  • Use templates to make new notes with pre-filled content
Click and hold the plus button to make a new note from a template, great for those notes that have a standard format, like meeting minutes and forms.
New
  • Powerful sharing sheet to work with Agenda notes from inside other apps
  • Click and hold on the history navigation buttons to get a popup menu of recent options
Improved
  • Dropbox sync is much faster, especially for the first sync of a device
  • Undo navigation is more natural. It now goes back to the beginning of an undo change, instead of jumping back to the location of the previous change
  • Performance improvements for loading images
  • Added haptic feedback to checking off a checklist item (iOS)
Fixed
  • Improved behavior when the app is in the background, to prevent crashes
  • Improvements to clearing data when you turn off sync
  • If you typed an emoji, the text following would be in a fixed-width font. That is now fixed
  • If you deleted back to the start of a paragraph, it could pick up the heading style of the previous paragraph. Fixed
  • List markers could sometimes be the wrong color (eg dark when in dark mode). Fixed
  • Deleting at the start of a note could delete forward. Fixed
  • Fixed an issue where it was not possible to put the cursor in an empty list item
  • On rare occasions, lines could start multiplying rapidly. Fixed
  • Attachments could be lost when dragging notes between projects. Fixed
  • Fixed an issue where upon dragging the sidebar could become blank
  • Fixed an issue where buttons would stay dark instead of light after switching to dark mode
  • Crash when pasting URLs from Chrome or through TextExpanders
Insert shared links, images, text, or files directly to Agenda from anywhere using the powerful sharing extension in Agenda 10.0.
Version 10.0.1
Improved
  • Added a tooltip that shows the full date when hovering over relative date of a note (macOS)
  • Small localisation fixes
Version 10.0.2
Fixed
  • Fixed problems with touchpad/mouse support on iPad
  • Fix for an issue where reminders created via Agenda on iOS would not sync
  • Better handling of license updates when the window gets closed
  • Fixed an issue when selecting the Template Manager without having purchased the premium features
  • A crash that occurred when showing the sign in for the community has been fixed
  • Some localization fixes
  • Fixes for various crashes
Version 10.0.3
Improved
  • The new Edit > Checklist > Sort Checked to Bottom menu now extends to the enclosing scope of the selection, rather than only the selected text. This means you can use it by simply putting it in one item of a list
Fixed
  • The Sort Checked to Bottom menu was not working when checklist items were mixed with other list types. It works now
  • Images and pencil drawings could sometimes disappear when at the end of a note. This is now fixed
  • Extra out-of-date data could appear when using copy and paste on iOS. This has been fixed
  • Dragging images between notes should not longer cause a crash
  • Some odd editor behavior involving tags has been fixed
  • Layout issues have been fixed that could cause notes to be the wrong size in landscape orientation on iOS
Version 11.0 with Widgets, Scribble, Note Appearance Customization, Accessibility, and 7 new languages
New Premium Feature
  • You can now choose to have a more subtle tag appearance
  • Unordered lists can be shown with a dash or a bullet
  • Checked off list items can be shown grayed out or with a strikethrough
  • Sample content shows how your notes will look as you change appearance preferences
Change the appearance of your notes with more subdued tags, bulleted instead of dashed lists, or checked off list items that are either more accentuated by striking them through, or subdued by greying them out.
New
  • Complete support for the VoiceOver and VoiceControl accessibility feature on iOS and iPadOS (macOS in beta)
  • Full iPad trackpad support
  • You can now use two finger swipe on the iPad trackpad to open and close the side panels
  • Agenda now appears as option in the Services menu on MacOS
  • You can now use two finger swipe on the trackpad to open and close the side panels
  • The Agenda preferences are now contained in different tabs
  • You can choose not to have an empty note added to new projects
  • You can set the first day of the week for calendars
  • Now you can choose if text dates are relative to today or not
  • You can choose if the notes from linked calendar events get imported into Agenda
  • You can choose to have “all day” reminders created by default
  • You can create notes linked to an event or day from a template
  • You can now insert placeholders in templates, which get pre-populated when you make a new note from the template
  • Support for actions has been introduced. Eg. You can type \date, and Agenda will in insert the current date
  • The \remind action now also has a new set of supported parameters, like all-day, list and title.
  • Placeholder actions in templates now allow you to have standard content entered dynamically, such as the current date, see Creating and Using Templates - #4 by system
  • The \shared-content placeholder can be used in templates so that when content is added via the sharing extension and x-callback-urls, it is inserted directly where you want it
  • You can now use templates in x-callback-urls and link events to your notes as well. In addition we added the option to not select the note that is edited through the x-callback-url
  • It’s now possible to create new categories using x-url-callbacks, as well as setting the completed, pinned, footnote, and collapsed state.
  • You can now create new notes in the sharing extension
  • Agenda now better supports auto-fill of passwords in the preferences
  • The sharing extension allows creation of new notes with templates
  • You can now swipe the left edge of the sharing extension to see the navigation list (iOS)
  • The gutter insert popover on iOS + iPadOS, and keyboard bar on macOS now includes the date and time
  • Attachments and Reminder shortcuts now also work in templates
Widgets on iOS14 and macOS11 provide a quick glimpse of your most relevant notes right on the Home Screen, and they are all only one tap away.
Improved
  • Dramatically improved performance when switching between projects, scrolling, search, and performing certain actions.
  • The note title area has been redesigned to suppport multiple line titles
  • The style popover you get by clicking the button on the left of the text editor now applies to the current selection instead of the paragraph
  • The style popover has many new options macOS
  • The menu under the cog/gear button at the bottom of notes is much simplified.
  • On iOS the cog/gear menu actions have been folded into the dot button next to the title (also available on iPadOS).
  • Major performance improvement when switching between projects and scrolling through notes
  • The menu for the yellow dot has been rearranged, as well as the collapsed note indicator
  • The navigation of the sharing extension has been improved, with easy access to recent notes
  • The overviews section of the sidebar has been redesigned to be clearer
  • The sharing extension is more efficient
  • Some content is better handled in the sharing extension
  • Multi-day selection on iPad is much smoother
  • Agenda will use the last used duration and time for new events
  • The last selected sort order is used as the default for new projects
  • When you mark a note completed, you are now prompted about whether it shoud be taken off the agenda
  • We now save the notes before printing
  • More performant and smoother showing/hiding of side bar and inspector
  • Improved import of folders with many apple notes
  • The info menu now includes the archived and completion dates
  • When sharing an Agenda file, the agenda sharing extension should no longer show in the options
  • Sharing a markdown file on iOS now gives the .md file extension.
  • Improved support for macOS11 Big Sur, including an updated App Icon
Screenshot 2020-08-19 at 15.18.10
The gutter menu has been redesigned and works now on the selection, in line with how the keyboard bar works on iOS.
Fixed
  • Certain layout issues, which could crop note content, have been fixed
  • Improved performance of scrolling in notes with images
  • Resolved an issue where chinese characters could be lost in edits
  • Upon launching the app the search field is properly restored if a search query is put back
  • Sometimes Agenda could jump to the cursor during scrolling. This is fixed
  • Prevent Agenda crashing when in the background, which would cause it to “forget” which screen you were in
  • Fixed problem where arrowing in a text view would not scroll it every time
  • Fixed an issue where inserting a newline at the start of a checked item would cause it to become unchecked
  • Better resizing of notes when dictating
  • Fixed the “Move to Beginning of Line” on macOS
  • Fix for Chinese puncation being inserted twice on iOS 12.4.
  • Fixed blurry images and PDFs on screen
  • Fixed missing text in save overview dialog
  • Fixed an issue where dismissing the crash report would leave the app in an inactive state
  • Fixed an issue where using english due tags like #due(in 2 days) would not work
  • Fixed an issue where relative date in the past would be displayed with just the weekday, which would be confusing in most languages except English
  • Fixed an issue where restoring the position in a project would be incorrect
  • New notes from a template now honor the on the agenda status as defined in the template
  • Localization improvements
ScreenFlow
Handwrite your notes using the Apple Pencil and Scribble anywhere in the app where text is expected, and your handwriting will be converted automatically to typed text.
Version 11.0.1
Fixed
  • Quick Reminders and Events can now be created by clicking the day headers in the inspector again
  • Agenda version 11 now runs again on macOS 10.12
Version 11.1
Improved
  • New projects are now added at the end of the existing list of projects in its category
  • Improved consistency and behavior of contextual menus for notes. Also added the Share option.
  • Added nicer URL shortnening for Slack URLs
  • Added the ability to create a new note directly in a project of choice through the contextual menu in the sidebar or by holding the alt/option key while selecting the File menu
  • Copied rich text from notes now correctly changes the look of tags and includes the attached images and files
  • Improved arrow key navigation through notes
Fixed
  • Fixed the issue where using an emoji in the title could lead to odd mono-spaced font usage
  • Fixed an issue with undo where undoing the creation of a new note would crash Agenda
  • Fixed a crash when trying to insert photos, sketches, or performing dictionary lookups, in notes with tags or images
  • Fixed an issue where the date was not properly removed from existing notes when saving them as a template
  • When showing and hiding the inspector the calendar will no longer scroll to the top, only showing event placeholders
  • Fixed a logic bug where moving a note to after the last note would not work correctly if there would be footnote notes
  • Fixed a number of appearance issues under dark mode
  • Improved stability
Version 11.2 with support for macOS11 Big Sur and various improvements
New
  • Introducing the Relevant Notes Agenda Widget in macOS 11 Big Sur
  • Added the ability to choose the eligible notes for the Relevant widget to be from all notes, or on-the-agenda, today, or upcoming notes only. Completed notes are no longer shown in the widget.
  • The project icons in the sidebar now show when a project contains notes that are marked as On the Agenda
  • Added a “Sort notes by” menu to the View menu on Mac
  • Added support for relative dates in the \date action, see Creating and Using Templates - #4 by system
  • Added the move text up and down and sort checked items keyboard shortcuts on iPadOS
Improved
  • Agenda is now fully compatible with macOS 11
  • The reminder editor now honours the “Create All-Day Reminders by Default” preference setting
  • Improved editor behavior for text formatting, and auto-correct, especially when using non-roman languages and accented characters
  • Improved behavior when using Scribble
  • Improved indentation behavior in the editor where hitting delete will now de-indent in addition to shift-tab
  • Improved display of permanent legacy scrollers
  • Improved scrolling while editing long titles
  • Improvements to scrolling in the sharing extension
  • Improved output of prints and exported PDFs
  • Reminders created using markdown will no longer be Untitled and instead receive the note title
  • The calendar popover now always shows as a modal sheet to prevent it from shrinking in landscape
Fixed
  • Fixed an issue where the cursor would jump to a different location upon tapping in the text
  • Fixed an issue hiding and showing Agenda in dark-mode could leave the notes panel with a white background
  • Fixed an issue where notes assigned to a day in one timezone, would appear as multiple days in a different timezone
  • Fixed an issue where styles like bold and italic would not work in empty notes
  • Fixed an issue where formatting of dates in the widget wasn’t according to the system settings
  • Fixed the date pickers in iOS14 to show the wheel style again
  • The recently edited and related notes panel no longer show notes that have been moved to the trash
  • Template notes should no longer appear in the list of related and linked notes in the related-sidebar
  • The \remind shortcut now properly parses times with minutes
  • The calendar popover now also more reliably opens on the correct day
  • Fixed an issue where upon editing future reminders the time and date would revert to today
  • Fixed the issue where the template title would not be visible in dark-mode
  • Fixed an issue where the sidebar would scroll behind the window buttons
  • Fixed an issue where pasting content on the last line would sometimes make the content end up on a previous line
  • When inserting shared content the cursor should correctly move to the end, and inserted checklist items should be correctly unchecked
  • Fixed an issue where the current note would not be properly highlighted in the recently edited list
  • Fixed an issue where the sidebar scroller would be clipped on macOS 10.14 and 10.15
  • Fixed an issue where inline formatting in numbered lists would not work correctly
  • Fixed a crash when rearranging projects in the sidebar
  • Resolved various small user interface glitches
  • Small UI tweaks and fixes
Keep your most relevant notes at hand by adding the Relevant Notes widget in macOS11 Big Sur
Version 11.2.2
Fixed
  • Fixed the issue where on macOS 11.1 Big Sur the window buttons went missing
Version 12.0 with Tables, Horizontal Rules and Agenda Invitations
New Premium
  • You can change the text alignment of columns in Agenda’s new tables
New
  • You can now insert tables into your notes
  • Add and remove columns and rows in tables
  • Use inline styles like bold and italic in table cells
  • Create a table with a text shortcut: “|||”
  • Add horizontal rules to divide up your notes
  • Create a horizontal rule with the text shortcut “***”
Improved
  • The Note menu has now been split into a Note and separate Insert menu
  • Now showing the paragraph dot also for empty notes on macOS
  • Widgets now show a more specific title depending on their configuration
  • Adjusted the caret on iOS to make it look better with widgets and attachments
  • When selecting text the note now scrolls up and down if needed while the selected text extends (iOS)
Fixed
  • Fixed issues in the window toolbar on macOS 11 Big Sur, including the issue where the window close, resize and fullscreen buttons went missing after the macOS 11.1 update.
  • Fixed a bug where editing subcategory names could lead to inclusion of the parent category name(s)
  • Fixing the issue where the note wouldn’t always scroll up if the keyboard would come on screen on iOS
  • Fixed an issue where the note would stop editing when switching between apps
  • Fixed the issue where upon inputting asian text characters the note would not resize.
  • Fixed a crash when switching projects or choosing Show Project in an overview
New in version 12 is the ability to add tables to your notes, as well as horizontal dividers
Version 12.0.1
Fixed
  • Fixed a crash on macOS 10.13 and earlier whenever a table was created
  • Inserting a link to a project or note on iPad now works again
  • Fixed an issue where sharing large notes on iOS could crash Agenda
  • Fixed an issue where the date picker would not be visible when having set Agenda to use its light theme with iOS or iPadOS set to use the dark theme.
  • Fixed a crash when undoing adding of a row or column in a table
  • Text in a table cell could sometimes disappear, particularly after pasting. This has been fixed
  • Fixed issue where typing with a multi-cell selection would cause text to appear in the note
  • Horizontal rules and tables were not properly working in templates. Now they are.
  • More reliable Sign in with Apple workflow
  • Stability improvements and fixes
Version 12.0.2
Fixed
  • Fixed a crash when syncing with Dropbox on the latest beta macOS and iOS
  • Cell content could be lost when copying cell contents between tables. This is fixed
  • Better support for the Polish language
Version 13.0 with Open Quickly, Keyboard Navigation, Split and Merge
New Premium
  • Quickly open your projects and notes by typing a few characters.
  • Pick at which size full-width attachments are displayed.
open_quickly@2x
All menus in Agenda now support keyboard navigation, and those showing notes, templates and projects can be filtered if you pull down the menu or simply start typing if you have a hardware keyboard. Even better, the new Open Quickly premium feature allows you to just hit option-space and instantly find the note or project you are looking for.
New
  • Navigate much faster through menus and calendars thanks to added keyboard navigation and filtering support.
  • You can now easily duplicate, merge, or split notes, as well as move or copy the selected text to a new note or start a new note after the current one.
  • Days with notes are now indicated in the calendar pickers.
  • Quickly jump to a date in the calendar picker by starting to type, or by picking the option “Type Date or Range” in the presets.
  • Filter notes marked or unmarked as “Done” by tapping the dot next to the search field.
  • The search field now recognizes when you try searching for a date.
  • Added the option to expand a date filter to apply to all projects, or create a smart overview straight from the day filter.
  • Added the replace-note x-callback-url action that allows to replace the text of an existing note instead of appending the text.
Improved
  • Much improved performance in notes with attachments. Lower memory usage also means better stability, especially in the sharing extension.
  • On iOS the gear menu has returned in selected notes, on macOS the gear menu is now consistent with the one on iOS and iPadOS.
  • The dot menu on macOS now features the same Other actions entry as on iOS and iPadOS.
  • It is now possible to reorder pinned notes and footnotes.
  • The day filter in the related panel now always shows the plus button to create a new event or reminder.
  • Improved layout of the template editor on iOS.
  • The small dot to re-center the calendar to today now shows more reliably.
  • Improved scrolling and insertion pointer behaviour on iOS and iPadOS.
  • When signed in with Apple the (private) email address used is shown in the preferences.
  • Added an explanation on how to restore previously purchased features.
  • Amazon, AppCenter and Radar links are now shown in a nicer way.
  • Undo of edits in tables now works much better.
  • Agenda is no longer fetching from CloudKit in the background, which actually doesn’t impact things much in terms of sync responsiveness, but should resolve crashes and high-battery usage while the app is in the background.
  • Localization improvements, including correct display of dates in the past in Chinese.
Fixed
  • Moving notes could leave notes selected in an inconsistent state on macOS, this is fixed now.
  • Fixed several text inset and layout issues on iOS and iPadOS, preventing search results and insertion pointer to go under the keyboard.
  • Fixed an issue where the header in the sharing extension would grow too large.
  • Switching to and from another app no longer ends editing or changes the scroll position on iOS and iPadOS.
  • Links in exported PDFs are now coloured blue on macOS.
  • Fixed an issue where the sharing extension would close when trying to share to a note containing a table.
  • Fixed an issue where a wrong date format could make the date and time insertion stop working.
  • Title changes are now taken into account when creating an Agenda link.
  • Editing of links on iOS and iPadOS now works more reliably.
  • Copy and Paste, and drag and drop, of images between Agenda notes now works.
  • When using custom date formats in templates it no longer affects the insertion of dates in normal notes.
  • Fixed some duplicate and non-functional keyboard shortcuts.
  • Fixed some issues with Chinese text entry.
  • When ending a search, sometimes yellow highlights could remain ‘stuck’ in notes. That is fixed.
  • Fixed an issue where upon typing the keyboard response would start to slow down, and in fact improves responsiveness while typing significantly in general.
  • Fixed an issue with parsing of list markdown when the line would also contain URLs or tags.
  • Fixed an issue where table alignment and column/row editing would not work properly.
  • Fixed crashes when trying to share notes.
  • Fixed a crash when closing the template editor.
  • Fixed an issue where upon indentation for example, text input by swiping the keyboard would no longer work. This also resolves an issue where the “Agenda_Insertion_Pointer” would appear in the suggestion bar above the keyboard.
  • On iOS the sidebar now automatically closes after editing the name of a new project.
  • Improved layout of wrapped lines in the popover menus.
  • Sync could fail to work if you used Settings app to clear the Agenda cloud data. This is fixed now.
  • Fixed a number of crashes.
Version 13.1 with enhanced Today overview and performance improvements
New
  • It’s now possible to go to the next and previous days in the Today overview, or select a day or day range to display
  • Week numbers can now optionally be displayed in the calendar in the related panel. Also added in the tooltip when hovering over a day.
  • Added a Move Unchecked to New Note option under the Edit > Checklist menu
  • Added table edit actions to the table cell contextual menu
  • Added the get-identifier x-callback-url to allow retrieveing the identifier of a note or project
  • Added a preference to disable the option-space shortcut to trigger Open Quickly, for those who heavily require on this shortcut to insert non-breaking spaces
New in Agenda 13.1: the Today overview now allows stepping through days using the same type of arrow buttons used in the calendar. You can even select a custom range using the calendar icon that is revealed after clicking or tapping the loupe icon.
Improved
  • Significantly improved performance when working with larger libraries and with projects or overviews with many notes
  • Much improved memory usage for attachments
  • Much sharper display of PDF attachments in notes
  • Improved performance of text editing and loading of notes with a lot of text
  • Improved detection of dates in titles of notes that prevent incorrectly assigned dates
  • Tables now put the cursor in the first cell when created
  • The precede by new note action now works as expected when the note starts with a list and also correctly selects the note title of the newly created note
  • Done and undone status now work in smart overviews and is showing in the recent and related panels in the inspector.
  • Improved performance of navigating through notes using the arrow keys on iOS and iPadOS
  • When using the Apple Pencil, the note title is now only enlarged if it takes up almost all space. The behaviour of enlarging selected notes when using the Apple Pencil is now also less jumpy.
  • Improved tabbing behaviour in the calendar picker on macOS
  • Exported PDFs and prints now contain higher resolution images, and clickable links on iOS and iPadOS
  • More reliable and predictable behaviour of the round circle to jump to today or the assigned date of the selected note in the calendar
  • On iPhone the text “Assign Date or Link Event” has been replaced by the same calendar icon as used on macOS and iPadOS
  • Print jobs now have a title, which is suggested when using Print → Save as PDF on macOS
  • x-callback-url errors are now called according to the specification
  • Whitespace is now trimmed from email addresses in the Agenda account login form
  • Markdown files shared from the Files app should now import in Agenda instead of triggering the sharing extension
  • Updated keyboard shortcut for cut and copy unchecked items, which now also work without any selection (collecting all unchecked items from the entire note).
  • Updated localizations
Fixed
  • The calendar picker now works correctly with non Gregorian calendars, like the Bhudist calendar
  • Fixed a crash that could occur while taking a picture and rotating the device on iOS
  • Fixed an issue where the title of new notes would not be selected in its entirety on iOS and iPadOS
  • Fixed an issue where typing in the title field of new reminders would shift focus to the searchfield instead
  • The next 10 days and last 10 days preset now covers 10 days instead of 11
  • Attachment thumbnails now properly switch to dark or light mode where appropriate
  • Fixed an issue with selecting, copying, and editing of table cells
  • Fixed an issue where headings entered using the markdown shortcut would not be recognized
  • Fixed an issue where showing the table of contents on iPad would mess up the trackpad pointer behaviour
  • Improvements and fixes to Dropbox sync
  • Added additional safety measures against accidental overriding of data during sync
  • Improved copy behaviour through the gear menu in the gutter popover, which also now features tooltips and correctly switches between dark and light mode
  • Fixed the Copy as HTML command in the gear menu on macOS
  • Fixed an issue where upon going to or coming from fullscreen or upon rotating the device, the height of notes would be incorrectly calculated
  • Fixed a crash when archiving or unarchiving projects in the sidebar on macOS
  • Resolved a number of crashes
Version 14.0 with Powerful Tags, Auto-Completion, Tag Browser, Editable Attachments and more
New Premium
  • Change the color of tags in your notes for an even more powerful tagging system
  • Filter the sidebar to only show projects that have been recently visited or edited
  • You can now display lines or a grid when making a drawing on iPadOS
  • You can now import and export your notes as markdown, including attachments, in the TextBundle format
  • Added the option to export your notes as HTML on macOS
  • Enable automatically renewal of your 12 month period of new premium features and save 15%
New
  • Agenda now contains a powerful auto-completion system for tags, people, emoji’s, internal links and actions (more below)
  • Added a tag browser to give an overview of all the tags used in your library, with the option to merge tags and create overviews from multiple tags easily
  • Back-links to linked notes automatically appear in the “Related Notes” section of the inspector
  • Attachments can now be opened and edited with other apps. Upon editing the attachments are automatically updated in Agenda
  • On iOS PDFs can be annotated using markup. The result is saved automatically in your note
  • Easily insert emoji’s by typing their shorthand in the form :tada:
  • Markdown formatting, conversion of text into a tag or person, as well as link shortening can now be prevented by typing a backslash preceding the text (e.g. \#fff)
  • Quickly add or copy a summary of a note based on checked or unchecked list items, used tags, or assigned people
  • Through the \template action you can now insert templates into existing notes, turning them into building blocks to quickly compose complex notes
  • It is now possible to export your notes all in one file, as one file per project, or one file per note. You can also select the scope of export more easily (selected notes only, entire project, etc.)
  • Link editing and insertion now features a dedicated inspector (option-click a link on macOS, or use ⌘K). It also allows the conversion back to plain text or the original complete URL
  • Pasted links will now be updated automatically to receive the webpage title
  • Added support for simple expressions, e.g. typing \expression(23*34) will result in the text “782”.
  • On iOS and iPadOS the black contextual menu shows many more options
  • It is now possible to delete your Agenda account from the Preferences
  • Agenda now has group licensing options available. Contact us for more details
Improved
  • Tags can now contains spaces, periods, as well as accented and unicode characters, e.g. #(very important) and @(Charles Parnot)
  • Much improved and consistent behavior of the text editor when picking up the correct formatting like bold and italic upon deleting text, indentation, moving to a new line etc
  • Added support for attaching folders and packages to your notes, these are transparently turned into zip files
  • Quickly open now works much better with languages like Chinese and Japanese
  • The searchfield in the calendar picker now allows for dates further in the past
  • The related notes panel in the inspector now shows an icon explaining why notes are related
  • The Agenda file format now preserves the category and project structure that was exported, which are restored upon import
  • On macOS you can now export an entire category of projects by contextual/right-clicking the category in the sidebar
  • Added the Agenda YouTube channel to the Help menu on macOS and the Help and Support section on iOS
  • Added the ability to get the identifier of the currently selected note and project using x-callback-urls
  • On iOS and iPadOS you can now directly invoke Live Text through the plus menu
  • Added shortening of URLs from Gitlab, Bugzilla, Jira, and others
  • The text of links to another note or project is automatically updated upon editing the title of the object that is linked to
  • It is now possible to start a numbered list at a different number than 1
  • On iPadOS when holding the command key a neat menu is shown with all keyboard shortcuts
  • Reorganized the contextual menu on macOS to be simpler
  • Upon converting text to fixed-width or preformatted, tags, people and links are reverted back to their plain text variant
  • Adding multiple tags in a row now works better
  • Added a number of missing keyboard shortcuts that were previously present on macOS only
  • Added support for long-tap and double-tap/click to open an attachment directly, and option-click to preview on macOS.
  • You can now use the arrow keys on iOS to navigate from one note to the next
  • Added support for long-tap to open an attachment directly
  • Added support for dragged webloc files, for instance from the address bar of Safari and Google Chrome
  • Removed links from text should no longer reappear upon editing
  • Exported notes in markdown format and saved to Files now get the proper .md extension
  • Added the print option to the gear menu on macOS
  • Improved appearance of horizontal rules in exported RTF on macOS
  • Nicer aligment of text in attachment thumbnails
  • The insert menu on macOS now features icons
  • Tables on iPadOS are now displayed wider
  • Fixed the move text up and down, and de-indent keyboard shortcuts on iPad
  • Nicer spacing of icons in the keyboard bar on iOS
  • Better handling of return and arrow key navigation in the open quickly menu on iPadOS
  • Improved appearance of the search field placeholder and tag browser in dark mode
  • Now show insertion menu horizontally on iPad mini in landscape orientation
  • When inserting media we now show a shorter filename
  • When inserting files and links the selection is better maintained on iOS
  • Improved wording and layout of the premium features window, added a link to the terms of service
  • Improved cursor behaviour when hovering over the dot next to the title and links in text
  • Improved memory handling when fetching large notes
  • Fixed an issue where notes would not be properly sized after changing the width of the notes on macOS
  • When using a magic keyboard the on-screen bar no longer has a transparent background
  • Checking a checklist item should now set the edited date of the note
  • The window menu now shows a more informative window title on macOS
  • Agenda now keeps a rolling error log that can be helpful to
Fixed
  • The plus button no longer jumps away on iPadOS when using a trackpad
  • The today overview in the sidebar no longer gets stuck on a day in the past
  • When using automatic switching between light and dark mode on iOS, Agenda could sometimes end up in the wrong mode. This is fixed now
  • Tapping on checkboxes and attachments is now much more reliable
  • Fixed an issue where the date icon at the top of the inspector would partially disappear
  • Fixed an issue where the first character typed after a checklist item could appear as subscripted
  • Resolved data corruption and reliability issues when syncing with Dropbox
  • Markdown import of notes separated by horizontal rules now works properly, as well as parsing dates for these notes
  • Exported RTF documents now include the attachments associated with inline tokens
  • Fixed a number of issues with link editing that would prematurely parse links and lead to incorrect or broken links
  • Fixed a number of issues with losing indentation or formatting when using voice input
  • Upon pasting text on iOS the cursor should now reliable end up after the pasted content
  • When deselecting a note it should no longer leave a selection of the text visible
  • Fixed an issue where the wrong tooltip would be shown on the dot next to the title
  • Fixed an issue where clicking in text near the right-edge of the note would result in a jump of the note view
  • Fixed several appearance issues when using dark mode
  • More reliable prevention of url parsing in fixed width or preformatted text, or when pasting as Plain Text
  • Fixed an issue where checklist and reminder icons would appear very large in exported PDFs
  • Fixed an issue where upon indenting text a “AGENDA-INSERTION-PLACEHOLDER” would appear in the autocompletion suggestions on iOS
  • Fixed an issue where text input by swiping the keyboard would not work
  • Fixed an issue where some headers of popovers would appear transparant on iOS15
  • The text editor no longer loses bold formatting when trying to simultaneously use bold and italic for example
  • Related notes should no longer be shown for notes that have a reminder tag
  • Removing a star should no longer leave trailing spaces behind
  • Removed confusing detection of dates and events by the system that would not work with Agenda
  • Fixed an issue with pasting of Google Scholar links
  • Fixed a crash when trying to insert a new person with the cursor inside a tag
  • Agenda now uses a faster and more reliable data storage that should result in performance improvements across the board
Agenda 14 comes with a powerful auto-completion system that not only completes tags and people, but also gives quick access to a range of actions and suggestions, including inserting emoji’s, reminders, templates, and links to other notes and projects. Learn more about it here…
Autocompletion4
Version 14.0.1
Fixed
  • Fixed a crash when typing multi-byte languages like Korean
  • More reliable editing of attachments
Version 14.0.2
Fixed
  • Fixed an issue where arrow key navigation would interfere with typing multi-byte languages like Korean
Version 14.0.3
New
  • Added the get-selection x-callback-url to get the currently selected note or project.
Improved
  • The create-note x-callback-url no longer requires a project identifier or title. If none is provided the currently selected project is used.
Fixed
  • Auto-renewing is now available. Save 15% by opting-in to automatically renew for 12 months of new premium features.
Version 14.0.4
Improved
  • If you select and copy cells in a table, and paste RTF in another app, it will preserve the table. Previously, the table would be converted to lines of text
  • Improvements to autocompletion for Chinese. The insert menu can now also be triggered by typing two · (middle dot) characters in a row, and all markdown and action syntaxes now support both regular and width variants of square brackets, parentheses, colons and commas.
  • The random expression action is now available on both macOS and iOS
Fixed
  • Fixed an issue where tags and links could get lost during editing
  • Fixed problems with editing non-http links in the link editor
  • Fixed a crash that could occur when clicking in the editor, such as on a checkbox
  • Solved an issue where the today overview could get stuck on a day in the past
  • Solved an issue where replacing an existing link by pasting would not work
  • The agenda link is now correctly inserted when scheduling a previously unscheduled reminder
  • Fixed an issue where reminders could not be marked as completed
  • Fixed an issue where you could not switch notes in the sharing extension on older versions of macOS
Version 14.1 with text editor and autocompletion improvements
New
  • Sync activity is now shown as clouds moving across the “islands” button (requires macOS 10.14 and iOS 15)
Improved
  • Spell checking is much improved
  • A link is now inserted to a reminder when it is added to a note from the right panel
  • The related notes panel now includes links to whole projects
  • Now automatically select the first option during autocompletion
  • You can press escape to end editing of a list item on macOS
  • Pressing CMD-S no longer beeps on macOS. (It is not necessary to manually save)
  • Subsequent new attachments now get added with the same size setting as the one previously used
  • The tag browser now defaults to searching all projects, instead of the selected one
  • When pasting a numbered list, the numbers no longer get frozen, but will adjust to any existing list
  • The current project is now shown as the first option when creating a new note using the [[ shortcut
  • When the calendar panel is closed the other related note panels now show more entries
  • On older systems the icons in the insert menu are now darker to better stand out against the lighter menu background.
Fixed
  • For some users, purchasing via Paddle could get ‘stuck’. This is now fixed
  • Horizontal rules are now properly visible in dark and black mode
  • Fixed a crash that could occur in the sign in panel
  • Chinese and some other languages are now better supported in search fields
  • Fixed an issue in the sidebar with selecting the first or last item after viewing the community
  • Fixed some glitches in the notes panel
  • Fixed a crash during sync that arose for some users
  • Fixed a crash in the sharing extension
  • Using x-callback or shortcuts now fully saves edits before starting
  • Links showing with the wrong color now show correctly
  • Relative due dates now work again in saved overviews
  • Sharing panel could jump when you had a table in it. No longer happens
  • Fixed some dark mode issues
  • Fixed various issues in the text editor
  • Fixed a crash for pencil drawings appearing on some versions of macOS
  • The contextual menu no longer contains two share menus
  • When editing the title and display style of an attachment at the same time, the title edit is no longer lost
  • Fixed an infinite loop when editing certain numbered lists
  • Various other crashes fixed
  • Updated localisation
Version 14.1.1
Fixed
  • Fixed a crash on startup on iOS14
  • Dragged attachments now preserve the display style, and no longer disappear when dragged after a link
Version 15.0 with Text Highlighting, Font choice, Focus Filters, and support for Block Quotes and Syntax Coloring
New Premium
  • You can now choose from various fonts for note content
  • You can choose any color you like for text, highlights, note backgrounds, and categories
New
  • Added support for Focus Filters (iOS16 and macOS13), to hide projects/categories when you are focused
  • Started to add support for Shortcuts app, to be further rolled-out over the next few releases
  • Added coloring of text
  • Added highlighting of text
  • You can now choose a background color for notes
  • Now have support for blockquotes in text
  • Added code blocks, with syntax highlighting of programming languages
  • Added a number of Shortcuts that are visible in the Shortcuts app, Spotlight and Siri
Improved
  • There is a new category of widgets called “Favorites”, allowing you to pin any note you choose
  • Images and links now get included when importing from Apple Notes
  • Templates can now be set to generate a pinned note
  • Templates now support background color
  • The x-callback-url for open-note will no longer change sidebar selection if the note is already in the selected group
  • When pasting RTF text, Agenda will now better extract styles and apply them
  • Agenda identifies list types better when pasting from other apps
  • The gear menu at the bottom of a note now also has a Mark… item that shows the same options as shown when clicking the orange dot next to the title
  • Performance improvements in the text editor for long notes and notes with attachments
Fixed
  • Fixed an issue where old pencil drawings could not be edited
  • Fixed Evernote file import for attachments and tags
  • The x-callback-url for create-note now properly utilizes the selected project
  • Widgets will no longer show archived notes
  • Fixed problems where styles would be lost on an empty line
  • You can now import Agenda files again from the Files app on iOS
  • Paste and Match Style now works much better
  • Fixed an issue where checklist items in a template would disappear
  • Fixed an issue where reminders could not be added to a note from the inspector
  • Fixed a crash when trying to remove a star from a paragraph
Agenda 15 allows you to highlight and change the color of text in your notes. It also allows you to change the font that is used for your notes and adds block quotes and syntax highlighting of code fragments:
Version 15.0.1
Fixed
  • Fixed a number of crashes related to Shortcuts support, including one where the app would crash on launch
  • Typing cmd-F inside a note to start a search now works reliably
  • The previously selected project and note are now restored upon starting the app
  • Fixed a crash upon detecting an incompatible version after syncing
  • Minor improvements to the supported Shortcuts
