Greetings. I got the full feature of Agenda in hopes to add to my workflow but I am still wondering about App connectivity such as Airmail 3 and Things 3.
The Airmail connectivity is very vital to note taking as I reference email in much of my work.
The Things 3 maybe redundant it seems but much of my GTD is handled there.
I’m thinking of this as more a note taker than a planner.
There is basic integration now. For example, you can drag something from Things into Agenda to get a back link. You can also select a note in Agenda, and choose Edit > Copy As > Agenda Link, and paste that in Things to link to an Agenda note.
Can you be more specific about what sort of features you would like to see? What workflow would you like to support?
Things has been rolling out more extensive automation support. So it’s possible to create projects with full task lists and the like. It’d be interesting if I could tell Agenda to take a list of action items (or really, all tasks in a given note) and create a project in Things or OmniFocus from it without me having to copy it all over manually.
Update: You’ll be pleased to know that in the 2.1 update we now support the Things and Airmail sharing extensions, including the ability to directly send PDF emails:
Thanks for this new update! Maybe I am the only one to ask, but even if it would be possible to share Spark on Agenda, together Airmail and Things, would be really good.
Yes, it does! But it doesn’t appear like on Airmail, where the note is perfect like it is on Agenda itself and even the links are visible and usable. This doesn’t happen on Spark. :grinning
Spark is telling through its sharing extension that it only supports plaintext. Airmail advertises it can also handle RichText, hence that is what Agenda delivers it.
Good conversation. Now that we talk about linking, I’m trying to replace Todoist and move notes from Airmail to Agenda or at least create pointers, so I can look at the Agenda and get back to an email in Airmail
