You can create powerful workflows by automating Agenda, which can be done both at a high level using Siri shortcuts or the Shortcuts app for example, or at low-level through x-callback-url support for example. The possibilities are endless!
Tip: We have created a dedicated area in the community to automating Agenda using Shortcuts where users share their workflows and shortcuts, be sure to check it out.
App Shortcuts
Starting from Agenda 15, App Shortcuts are ways to quickly get one or more tasks done in Agenda through the Shortcuts app. By combining multiple Agenda Shortcuts, optionally with those from other apps you can create and automate your workflows. From the simple opening of a specific note from the Home Screen of your iPad, triggering a new note after a double-tap on the back of your phone, to complex workflows that grab all the things you need to do today from different apps and creates a new project in one tap.
Agenda for iOS also supports Siri shortcuts for common actions like opening a certain note, project or overview. Learn more about it here:
Search Notes in Shortcuts
You can use the Search Notes action in the Shortcuts app to find notes matching specific criteria. This is also available via x-callback-url. Search queries support action syntax like \color, \done, \pinned, and more, giving you the same power as in-app search from your automations.
Reference and Supported Shortcuts
Click here for a reference of the supported App Shortcuts…
Siri
You can use Siri to search your notes and interact with Agenda. For example, just ask Siri to search for something in Agenda, and you can preview the results directly. Siri also supports richer interchange of data between Agenda and other apps.
Control Center
On iOS, Agenda provides Control Center buttons that let you quickly jump to the Today or On the Agenda overviews without opening the app first. You can add these buttons in your device’s Control Center settings.
Agenda also supports x-callback urls. These allow you to couple workflows between apps and/or automate certain actions within Agenda. It’s also supported by Apple’s Shortcuts app.
A quick intro to x-callback-urls:
- The URL scheme is
agendaoragenda-notes - Commands currently include
on-the-agenda,today,open-project, etc. See the reference for a complete list. - For “open-project” and “open-note”, you can stipulate the target using a
titleparameter. - As usual, you can supply callback URLs via optional
x-successandx-errorparameters.
For example, to open Agenda to a note called “Meeting With Peta”, you could use this URL:
agenda://x-callback-url/open-note?title=Meeting%20With%20Peta
New in Agenda 23: the move-note action lets you move a note between projects from another app or shortcut:
agenda://x-callback-url/move-note?title=Meeting%20With%20Peta&project-title=Archive
Reference and Supported Actions
Click here for a reference of the supported x-callback-url actions…
MCP (Model Context Protocol) Integration
Agenda includes a built-in MCP server on macOS that allows AI assistants to interact with your notes, projects, and categories. MCP is an open protocol that tools like Claude Code, Claude Desktop, Cursor, and Codex use to communicate with apps.
Enabling the MCP Server
The MCP server is off by default. To enable it, go to the Agenda menu and choose Integrations > Enable MCP. The server runs locally on your Mac at http://127.0.0.1:16106/mcp and is only accessible from your own machine.
The Integrations menu also provides options to copy configuration commands for connecting various AI tools, as well as a Claude Desktop plugin that can be downloaded and installed directly.
Available Tools
The MCP server provides the following tools for AI assistants to use:
Find and read
- search_notes — Search your notes by text, tags, dates, and other criteria
- get_note — Retrieve the full content of a specific note
- get_selection — Get the note or project you have selected in Agenda, so you can say “this note”
- list_projects — List all projects, optionally including archived ones
- list_categories — List all categories
- list_templates — List your note templates, to create a note from one
- list_overviews — List your saved overviews
- list_attachments — List the files and drawings in a note (new in Agenda 23.4)
- get_attachment — Get the original file of an attachment (new in Agenda 23.4)
Show in Agenda
- open_note — Open a specific note in Agenda
- open — Bring Agenda to the front and go to Today, On the Agenda, a search, a project, or a saved overview
Create and change
- create_note — Create a new note in a project, with optional file attachments
- append_to_note — Add content and/or file attachments to an existing note
- edit_note — Modify the content of an existing note, with optional file attachments
- move_note — Move an existing note to a different project
- trash_note — Move a note to the trash
- untrash_note — Restore a note from the trash
- create_project — Create a new project
- update_project — Rename a project, move it to another category, change its sort order, archive it, or move it to the trash and back
- create_category — Create a new category
- update_category — Rename a category, change its color, nest it under another category, or move it back to the top level
Calendar (new in Agenda 24)
- list_calendars — List your calendars, and which ones can be changed
- list_events — List the events between two dates, optionally in some calendars or matching a title
- get_event — Get one event, with its location, notes and linked Agenda notes
- create_event — Add an event to your calendar, optionally with a new or existing Agenda note linked to it
- update_event — Change an event’s title, dates, location, notes or calendar
- delete_event — Delete an event from your calendar. Linked notes stay in Agenda
- link_event — Link a note to an event, or remove the link
The calendar tools are free. They work with any event in your calendars, and you do not need Premium to use them.
Export
- export_pdf — Save notes, or a whole project, as one PDF file
Notes and projects cannot be deleted permanently through MCP. A note or project that an assistant moves to the trash stays there until you empty the trash, and categories cannot be deleted at all. Calendar events are different: delete_event removes the event from your calendar for good, just as deleting it in the Calendar app would. For a repeating event, only that one occurrence is changed or deleted.
Connecting AI Tools
To connect an AI tool to Agenda’s MCP server, use the configuration command from the Integrations menu, or set it up manually:
Claude Code:
claude mcp add --transport http agenda http://localhost:16106/mcp
Claude Desktop / Cursor:
Use npx mcp-remote http://localhost:16106/mcp as the command in your MCP configuration. Alternatively, install the Claude Desktop plugin directly from the Integrations menu.
Codex:
Add the following to ~/.codex/config.toml:
[mcp_servers.agenda]
url = "http://127.0.0.1:16106/mcp"
The create_note, append_to_note, and edit_note tools support adding file attachments to notes. Attachments are sent as base64-encoded data, so an AI assistant can read a file from your Mac, encode it, and attach it to a note in one step. For example, you could ask your AI assistant to “attach this PDF to my Meeting Notes” and it will handle the rest.
Each attachment requires a filename (with extension, so Agenda knows the file type) and the base64-encoded file data. You can optionally control how the attachment is displayed using displayStyle (inline, thumbnail, thumbnail-with-details, or full-width) and displaySize (small, medium, or large).
Limits: up to 20 attachments per request, with a total maximum of 100 MB of file data.
Getting files out of a note (new in Agenda 23.4)
An assistant can also take a file back out of a note, for example to read a PDF you attached or to upload it somewhere else. The list_attachments tool lists the files and drawings in a note. The get_attachment tool then makes a read-only copy of the original file, with the name you see in Agenda, and gives the assistant its location. The copy is temporary: Agenda removes it the next time it launches.
If your AI tool cannot read files from Agenda’s folder, it can ask for the contents of the file directly instead (up to 100 MB, files only). A folder or package is given as a folder, and a drawing is given as its preview image. Attachments in locked notes are not available.
Help Resources
The MCP server also exposes help resources covering common topics from the Agenda documentation, so AI assistants can look up how features work and provide better answers about Agenda.
What You Can Ask
Once your AI tool is connected, it can read and modify your notes on request. Some examples of what works well:
- “Summarize my meeting notes from this week into a new note in the Weekly Reviews project.”
- “Find anything tagged
#followupthat mentions Anna and list it.” - “Add the action items from this PDF to the bottom of my Project Kickoff note.” (the AI can attach files too)
- “Move the ‘Q2 Planning’ note from Drafts into the Strategy project.”
- “Create a new project called Holiday and seed it with a packing list.”
- “Take the invoice PDF from my ‘March Billing’ note and tell me the total.”
Because the MCP server runs locally on your Mac, your notes never leave your machine on the way to the AI tool — only the specific text the assistant reads or writes is sent through it.
Troubleshooting
If your AI tool can’t see Agenda:
- Is MCP enabled? Check Agenda > Integrations > Enable MCP. The menu item flips to Disable MCP when the server is running.
- Is Agenda running? The server lives inside the Agenda app — if Agenda quits, the server stops with it.
- Did the AI tool reconnect after enabling MCP? Some clients cache the connection at launch. Restart the AI tool if it was running before you enabled MCP.
- Port 16106 in use by something else? A quick test from Terminal:
curl http://127.0.0.1:16106/mcpshould return a response (not “connection refused”).
Note: The MCP server is only available on macOS.
