Agenda and Omnifocus
I love Agenda and it has quickly become a part of my workflow. The only thing missing for me is a close integration with Omnifocus. That would make it perfect for me.
Can you give us an idea of the type of integration you would be looking for? Eg ability to add a checklist task to omnifocus? Add a link to an omnifocus item?
I think you can probably integrate a little with the share sheets of the two apps. It put a link to a note in omnifocus, and vice versa.
In addition to the questions from Drew, please note that the Talk section of this community has a number of threads discussing how to have Agenda and OmniFocus work together, for example:
The “Share Note” menu greatly assists my primary workflow (Calendar, OmniFocus, Agenda). Also great to see DevonThink in there. Unfortunately OmniPlan has poor notes capability and I use “Copy as Agenda Link” to add meeting notes to OmniPlan tasks. Would be awesome to see some sort of integration between the two apps.
You hit the two forms of integration that came to my mind. I’d love to link Agenda documents to Omnifocus items. Add checklists to Omnifocus would also be cool.
Have you tried the sharing extension for a note? Eg. Cog menu at the bottom to the note, and then pick OmniFocus? I would think you could add a backlink to Omnifocus to the note in that way.
Thanks for the tip, works great. Still having a list of tasks as I have a list of appointments and connect it would be even better. :slight_smile:
This is a trick I learnt from the LearnOmnifocus blog / course.
In the Services menu, there is a service to Send to Omnifocus Inbox.
If you select the part(s) of the note in Agenda that you want to send to Omnifocus, then go up to Agenda in the Menu Bar, hold it down to select Settings / Preferences and then Services.
In Services, select Send to Omnifocus Inbox and a dialogue will be generated like the Omnifocus Quick Entry dialogue.
If you save, the task will be placed into the Omnifocus Inbox. However, you can enter more details like Project and Due Date etc. If you enter the project, the task will be filed in the relevant Project.
In either case, there is a link back to the Agenda note.
Of course, in the MacOS Settings app you can assign a keyboard shortcut to the service.
This trick also works going from an email to Omnifocus. I don’t know a way of linking an email to Agenda to create a new Agenda note to create a link between all 3.
Omni Automation has an Agnda to Omnifocus plug-in.
