Could you explain more on that?
Actually because of the italic font is not implemented in Chinese characters.
If we translated it to Chinese, it will be not that easy to determine the difference between each item.
I see, the italic format has no effect on Chinese characters. Maybe we should consider this as a bug?
Maybe we can still translate the style? Because even if you can see the difference in English, it has nothing to do with Chinese.
Time to summon @mekentosj for your advice.
We indeed need to have a look what we’ll do here, for now let’s just assume we can differentiate the two and translate the styles, we’ll then decide whether to not show them as options or if there are alternatives.
Don’t really think you can exclude styles based on the chosen language. To begin with, it is perfectly acceptable for a Chinese user to write some roman text, and there the styles apply. So I don’t think removing styles is the answer.
Update: We have now moved the Simplified Chinese translation of Agenda to the OneSky platform.
Update: Hooray, the Traditional Chinese translation of Agenda is now available as part of Agenda version 10.0
. We’d invite everybody to give it a try and let us know if you find any aspects that can be improved, need to be corrected, or are giving issue. Join me in thanking all translators who worked so hard and with so much passion to add the Traditional Chinese translation of Agenda!
I’m soooo glad to see the Traditional Chinese version finally comes to reality!!! However, there’re some mistakes should be corrected instantly cuz they are on an important place–Preview pages on App Store.
BTW I would like to know what can I do to help improving the translation. (Using OneSky or…?)
I have corrected the mistake in OneSky, there is a typo in the word 「大氣層」vs「大氣屠」, thanks @nicofan1226 for reporting the issue.
Thanks! We’ll update the screenshots in the next round.
I will spend some time in the sample document in the coming week. I think they needs more polishing but there were too many words. Hope I can catch up before the next release.
你好,请问是否可以把软件设定有中文语言吗
Yes, it will automatically do so if you have your system set to use Chinese as the first language.
通常您的 Mac 如果是简体中文,Agenda 会自然显示中文,想要设定个别软件与系统不同语言的话,可以在“系统偏好设定”>语言与地区>app 标签中分别设定
Update: We have moved from OneSky to Crowdin for translating Agenda to Traditional Chinese ![]()
Happy Spring Festival 2021 to all Chinese speaking Agenda users! 新春快乐
