Lists, Tables, and Summaries
Lists
With Agenda, you can mix hierarchical lists in with your other notes. The app supports number lists, bullet lists, and check lists.
Creating a Dashed or Bullet List
You can create a bullet list on Mac using the menu item Format > Lists > Bullet List. The list options can also be triggered by clicking the dot in the gutter to show the formatting popover and picking the first list option:
On iOS you find the list options by tapping the ¶ button in the bar above the on screen keyboard:
Once active you should see a dash (or bullet) appear at the beginning of the item. Pressing enter creates a new item. Here’s an example:
Alternatively, you can use markdown syntax to start a list. Just begin the line with a hyphen (-) followed by a space, and start typing your first list item. The paragraph will automatically turn into a bullet list item.
To exit the list, you can choose a different paragraph style from the Format menu (eg Body) or keyboard bar, or you can go to a new line, and press backspace to delete the dash or bullet.
Choosing between a dashed or bullet list
You can choose whether you would like to have unordered lists to begin with a dash (-) or bullet (•) in the Agenda Preferences. This change is reflected everywhere in the app, e.g. when printing, sharing, etc.
Premium: This feature is only available after you purchase the premium feature pack.
Creating a Numbered List
In a number list, items are numbered in order. Here’s an example:
Numbering applies to a single level of indentation; if you indent to create a nested list, it will have a separate set of numbers to the original list.
To create a number list on macOS, use the menu item Format > Lists > Numbered List, or use the markdown syntax by beginning your first item with “1.”, followed by a space and the item text. On iOS you find the list options under the ¶ button in the bar above the on screen keyboard.
If you want to have the list start with a different number than 1. or continue with a different number than the one succeeding the previous paragraph, you can do so by beginning your line with that number, followed by a period and a space, e.g. 5. Fifth Item
Letter and Roman Numeral Lists
In addition to standard numbering, you can create lists with letters (a, b, c) or roman numerals (i, ii, iii) using the \numbered text action. Type \numbered and choose the style you prefer from the options. This is especially useful for outlines or legal-style documents.
To exit the list, choose a different paragraph style, or press enter to create a new empty item, and then backspace to delete the number marker.
Tip: When you enter a return in between two items you will notice that the list starts again at 1. One way to prevent this is by using a so-called non-breaking (soft) return, which will bring you to the next line without starting a new paragraph. You can read more about soft returns here: Taking Notes
Tip: If you don’t want text like 1. Something be recognised as a numbered list, prefix the text with a backslash \ and Agenda will keep your text as-is (removing the backslash of course).
Creating a Checklist
Checklists are useful for tracking tasks or items you need to handle. Creating a checklist is as simple as selecting the menu item Format > Lists > Checklist on macOS, or using the ¶ button in the bar above the on screen keyboard on iOS and iPadOS. Here’s an example:
You can use markdown in various ways to create a new checklist. You can enter [] or -[] at the start of a line. To create an item that is already checked, use [x].
Checking Off in a Checklist
The advantage of a checklist is that you can check off items as they are completed. As you would expect, this is as simple as clicking on the circle to the left of the item. You can toggle a checked off item to be unchecked again by clicking the circle once more. On Mac there is also the option under the Format > Lists menu.
Choosing the look of checked off items
You can choose the way checked off items should appear in your note in the Agenda Preferences. By default the checked off item shows a greyed out checkmark icon with standard black text. If you like checked off items to stand out more you can opt for the options to have the text be stricken through, while if you like them to be more subdued you can choose to have the text be greyed out.
Indentation
All lists and other paragraph styles can be indented. Hitting tab is the easiest way to indent (and Shift-Tab to deindent), but you can also use the Format > Indentation menu on macOS, and the bar above the on screen keyboard on iOS and iPadOS:
Screenshot 2021-01-21 at 18.46.33
You can mix indented lists. For example, you could have a check list, where one item has a nested numbered list. Perhaps that item has a number of steps that you need to remember, so you enter those as a sublist to ensure you don’t forget.
Tables
Tables in Agenda are a great way to display multi-column or tabular data in your notes. You can choose the number of rows and columns as you see fit and can also style the text inside using inline styles as bold and italic.
Creating a Table
To add a table to your notes, on macOS you can use the menu Insert > Table, this will insert a new 2x2 table. You can also use the popover that shows when you click the small circle in the gutter of the note text area:
On iOS and iPadOS you can create one by tapping the table icon in the popup menu that shows after tapping the plus button in the bar above the keyboard:
There is also support for creating tables with a textual shortcut: you can type three pipe symbols (|) in a row to insert a table, i.e. |||.
Selecting table cells
You can select one or more table cells by starting to drag-select text in the cell and moving the cursor while dragging to the end of the table cell, or into a neighbouring cell. This can be useful to for example copy the contents of one or more cells for use in other apps, to cut and paste cells, rows, or columns to a different location within the same table, or move them into a separate new table.
Editing a table
Text in individual table cells can be entered and edited in the same way as text outside a table, Agenda even supports adding inline styles like bold, italic, etc. You will notice that three dots will show next to the row and column the selection is currently in. These can be clicked to reveal a number of options to edit the table.
Adding a table row
To add a table row:
  1. Place the cursor in a cell in the table where you want the new row to be inserted.
  2. Click or tap the three dots at the right of the table row.
  3. From the menu choose either Add Row Above or Add Row Below, which will insert a new row either above or below the row of the selected table cell, respectively.
On macOS you can also use the menu option Edit > Table > Add Row Above or Add Row Below.
Tip: If you hit the ⇥ (tab) key with the cursor in the last cell of a row, Agenda automatically adds a new row to the table for you. In general you can use the tab key to jump to the next cell of the table, but as a convenience doing so in the last cell will add a row for you.
Deleting a table row
To delete a table row:
  1. Place the cursor in a cell of the row to be deleted.
  3. From the menu choose Delete Row.
On macOS you can also use the menu option Edit > Table > Delete Row.
Adding a table column
To add a table column:
  1. Place the cursor in a cell in the table next to where you want the new column to be inserted.
  2. Click or tap the three dots at the bottom of the table column.
  3. From the menu choose either Add Column Before or Add Column After, which will insert a new column either left or right of the selected table cell, respectively.
On macOS you can also use the menu option Edit > Table > Add Column Before or Add Column After.
Deleting a table column
To delete a table column:
  1. Place the cursor in a cell of the column to be deleted.
  3. From the menu choose Delete Column.
On macOS you can also use the menu option Edit > Table > Delete Column.
Changing the text-alignment of a column
For certain kinds of data you might prefer a different text alignment than the default left-alignment, for instance numbers or currency looks better right-aligned. To change the text alignment of a column:
  1. Place the cursor in a cell in the table of the column you’d like to change the alignment for.
  3. From the menu choose one of the alignment options.
Advanced Tables
Agenda offers a number of advanced table features that give you even more control over the layout and organisation of your tabular data.
Header Rows
You can designate the first row of a table as a header row, which visually distinguishes it from the rest of the table. To toggle the header row, click or tap the three dots at the right of the first row and choose the header option.
Adaptive Column Widths
Table columns automatically adapt their width based on the content they contain, making better use of the available space.
Drag and Drop Reordering
You can reorder both rows and columns in a table by dragging them to a new position. Simply drag from the three dots at the right of a row, or the three dots at the bottom of a column, to rearrange your table.
Premium: Header rows, adaptive column widths, and drag and drop reordering are only available after you purchase the premium feature pack.
Rich Content in Table Cells
Table cells support much more than just plain text and basic inline styles. You can add tags (#), people (@), stars, reminders, links, highlighting, and even use autocompletion within table cells — just as you would in the rest of your notes.
Creating Tables from CSV or TSV
If you have tabular data in CSV (comma-separated) or TSV (tab-separated) format, you can quickly turn it into a table. Simply select the CSV or TSV text in your note and use the contextual menu to convert it into a table. You can also paste CSV or TSV data from the clipboard directly into a table cell selection to fill multiple cells at once. When copying table cells, the content is placed on the clipboard as CSV text, making it easy to paste into spreadsheets and other apps.
Summaries
Summaries in Agenda can be a convenient way to quickly extract the most important parts of a note that you can either add to your note or copy so you can paste it to a different note or to say an email.
Adding a summary to your note
To add a summary to your notes, on macOS you can use the menu Insert > Summary, and selecting the type of summary you would like:
Alternatively, you can use the \summary text action to directly insert the summary at the current position. This also works on iOS and iPadOS.
Copying a summary of your note
The same summary options can be found on macOS under the Edit > Copy As > Summary menu item. The resulting summary will be copied to the clipboard so you can easily paste it in a different note or in another app.
can a summary work across a collection of notes? say, several notes related to a project, or in a daily note across all notes for open actions, etc.?
Unfortunately it only works at a single note level at the moment, we’ll take your feedback on board and see if it could also be made to work with multiple notes.
Hi,
just a new user, and i’m wondering if it’s possible to adjust the column width on a table?
Regards
It isn’t possible at the moment, short of changing the number of columns. The problem is that tables have to work on different screen sizes, so fixing their width doesn’t work that well. It would mean you have to scroll the table sideways on iPhone, for example.
We hope to find a way to allow some form of column resizing in future, given this multiple device constraint, but it is not in there yet I’m afraid.
Hi Drew,
thanks for claryfing. Really dissapoint thought!
If you have ideas about how you would like it to work, let us know. The feedback is useful.
The guiding question is: If you have a bunch of columns at a fixed width on the Mac, what should happen on a narrow iOS screen? Eg. should the whole table scroll sideways? Should the table be scaled down so text is smaller than the rest of the text? Should the table wrap around into effectively two tables? None are really nice IMO
I’d also love the ability to use “Summary” to pull a specific tag from all notes within a project into a single note that I can pin to the top and keep it there. I would love not to have to 1) scroll between notes to see all my tasks, 2) copy/paste my tasks every time back into one central spot, and 3) use a different task management app.
Other than that, I love this app and use it all the time! Tutorials are really helpful as well :slight_smile:
Thanks for the feedback! We have some very powerful features planned for filtering searches which may help with some of these wishes. Hopefully you will be able to make summaries showing tasks still open, without copying them all to other notes.
The version of Agena I’m running (Version 16.1 (263) - Mac App Store + Premium through 16MAR2023) does not show any support for bullet point lists. I usually use dashed lists, but occasionally, I would like to put a bullet point list inside a dashed list for clarity.
Currently we just have the one list type (other than numbers etc). You can choose in the Settings/Preferences of the app for either dashes or bullets, but you can’t mix them, because at this point in Agenda they are the same list type, just shown with a different bullet.
Hope that explains.
Is there a way to add all values/numbers in a column or row?
I think it will work if you copy them and paste, but I could be wrong about that. Not sure if we already added that option.
Quick Question on tables.
In your examples I see black stars used as a way to rate. I think it’s really cool. How do you insert the star in a table?
It’s simply the star emoji you can get from Edit > Emoji & Symbols, or you can copy it from here: ★
Thank you! I was able to find ★ using your method on my computer. However it seems not to exist in ios/iPad os. Also it is not available if you use the shortcut “:” to add an emoji.
Now I know how to get it when needed. Thank you! I wouldn’t think an emoji would be so elusive.
Ah, I guess because technically it’s not an emoji but part of a different unicode range. We’ll see if it can be added to the “:” shortcut
That would be great if it was added to the “:”. Obviously not a priority.
Is there any way to center the first row of a table without centering the rest of the rows? This would treat the first row as a header row. I can’t find a way to do this so far…
Not yet, I’m afraid. Table headers would be a nice edition. We’ll take it along. Thanks for the feedback!
