pjones
February 25, 2019, 11:47pm
1
I will be using Agenda for journalling, amongst other things. I will need to create notes each day using a template that has some italicized headings, carriage returns, etc. Then, I will add appropriate text for that day.
I understand there is a callback url scheme, but I don’t think this can be used with rich text.
Can I accomplish this using Shortcuts?
You can use it with plain text, but use markdown formatting to get headings etc. That should work. Eg. For a heading, you use “# This is a heading”
Another option is to just copy the content of a “template note” each day. You could also use a tool like TextExpander.
pjones
February 26, 2019, 11:06am
3
This makes sense. Thank you for the rapid reply. Off to create some shortcuts!
Also make sure to have a look at this post which goes more into the use of template tools:
If you use Agenda for things like weekly catchup meetings, daily standups , prospective client meetings , and onboarding protocols , chances are you often find yourself using copy-and-paste of notes from other occasions, because the “agenda” is usually fixed.
Here I’ll show you how to create note templates in a few simple steps using text replacement utilities. This makes Agenda even more powerful, and can save you a ton of time. nmcp → No more copy and paste!
In this article I’m using TextExpa…
