Hi,
This is a very promising program.
Question: How do I get the title of each note listed under the prohect title on the laft panel? When I have lots of notes in a single project, it is difficult to find notes.
If this is not possiblem, then please read this as (in my view) and important feature request.
I assume one would want to be able to “open” and “close” this list under the Project tittle.
Thanks, best of luck in the near term polishing up this promising program.
Notes do not get listed on the left, only projects. But, you can click the title of the project at the top of the notes list, and get a menu that shows all the notes. You can quickly jump to any note.
Hope that helps.
I think we are unlikely to do that. I can’t think of another note taking app that does it either, simply because there can be so many notes. People have thousands, and listing them in the left sidebar would make it unusable.
We have a list of notes available for every project, if you select the project left, and tap/click the project title at the top. You get table of contents, and options to sort. That seems like a good compromise.
