Really small detail, but is there any easy way to enter a line (I like to separate text within my notes)?
Is there any easy way to enter a line (I like to separate text within my notes)?
Not at the moment but weāve seen this request a few times indeed.
Is there a way to do a block quote (not monospaced as code, but as a quote from a person)? That would be super handy to capture quotes from people during a meetingā¦
Also would love to have some audio recording support or integration with Just Press Record.
Would love to have some audio recording support or integration with Just Press Record
Agree, audio would be nice. Probably down the track. For now I would say just record with QuickTime and add after that (or Just Press Record).
You canāt directly do a block quote, but body text is indentable, so you can do something very similar. Just tab to indent, enter the quote, and shift-tab to outdent.
A post was split to a new topic: Block Quote Support
What about notes related to several projects? Any chance to link them or is it copy and paste?
Youāll find a good Talk article about this topic here: What to do with multiple project notes
Are there any ways to add a divider line? In some of my templates, it would be a lot neater looking if I could figure out how to add a divider line.
Insert Horizontal Rule (ā āH)
If that is the divider line you needā¦
Thank you! Iāll have to try it on my mac- it doesnāt seem to work on my iPad Pro with keyboard.
You can also type three hyphens on a line, to get a horizontal line.
Oh that worked perfectly, thank you!
