Pagico uses a tag format of @tagname.subtagname so you can find and sort by tagname and by subtagname just by inserting a period between subtagnames. This provides a hierarchical way to manage your tag names and view your projects. Just add a way to collapse the subtagnames into the parent tag name and you will have a hierarchical way to manage your limited visual real estate.
@kimheathman I use the same #tag.subtag structure in other apps and agree that it is powerful. As @Pat_Maddox mentions above, a close approximation in Agenda is the #tag(subtag) format. Itās not a perfect replacement, but you can at least do a search for #tag and see all of the subtag items together.
See: Tags, People, Emoji's, Text Actions and Links - #110 by Pat_Maddox
A post was merged into an existing topic: Polish - Polski
How do you change the width of a column in a table?
This isnāt yet possible, youāll find more discussion on it here:
Thanks.
+1, it would be wonderful to have a list of tags
You read our minds. Should be in one of the major updates this year. Stay tuned!
Hi guys! Could you please give us an update concerning tag (#, @) autocompletion and an estimated timeline? Making mistakes here leads to frustrating search attemptsā¦
We commented on it yesterday, see here Autocomplete of tags - #50
Hi there,
Reading the instructions it should be possible to use symbols in tags, but what symbols are prohibited? For instance the $ cannot be used, but I canāt find out if this is expected behavior or a bug.
Thanks.
At the moment indeed currently you can only use standard letter and number characters plus underscores and dashes. In the next update weāll bring major improvements to tags which also allows a way to have any symbol in a tag that you want, including spaces and dollar signs.
Iām surprised a Tag Browser and Tag Completion function hasnāt been implemented given how much Tag is touted as one of the main organising tool.
You will be surprised no moreā¦working on it now.
Hi all, donāt know if I missed something, in which case I apologize⦠I was thinking it could be helpful, in version 14, to add also a People browser like the one that was added for Tags.
Do you see it possible?
A people browser is next on the list indeed, stay tuned!
Note that the
duetag is just an example of a type of tag you can create with dates as values. The keyword is up to you, can also be saydeadline(2 days).
Iāve been trying this feature and unfortunately it doesnāt work with tags other than ādueā for me. For example "WAITING(28 April 2022)ā doesnāt work for me. When I change the tag to ādueā it works fine
You should be able to search on all waiting tags and/or all waiting tags marked with 28 April. The due tag is indeed unique in that it will search for all tags up to and including for example 28 April.
Great. Thanks. It wasnāt obvious to me from the article that āup toā only worked with the due tag, but now understood.
7 posts were split to a new topic: Deleting tags
