Synchronisation of links
If you set a link (e.g. to a pdf file) on one device the link will be synced, however it works only on the very device where it was originally set not on any other device. It would be helpful if the links worked on all devices (Macs)
Indeed at the moment links to files are only working locally. True support for attachments and inline images that sync the underlying files across your devices will be our main focus after the iOS release, see also The features we are working on right now…
