Hello,
just new to Agenda, trying to find good options to my way of work, I am wondering if there is any way of moving projects within a category, or if it is possible moving categories by drag and drop?
Moving projects is important, so I can move the most important project way up, so I got also a visible overview of actual situation. Same about categories as alphabetical sorting is not the best thing for a quick look what´s to do next.
Any infos about that? Would be good getting infos here, as I am just making a selection of trying to work with Agenda and waiting for the iOS version too as I am working with Mac and iPads all the time, or start working with Things which is already available for iOS too.
Manual ordering of projects and categories has indeed been a popular request, we hope to bring this possibility at some point, thanks for the feedback!
I came to the forum to look for an answer on how to move categories as my left hand panel is now a little messy. I see this can’t be done and the last ‘vote’ to have it implemented was just eight days ago. I’d like to add my vote too!
You can move projects to a different category through drag and drop, you cannot yet manually reorder categories and projects within categories, they are strictly ordered alphabetically at the moment. This is something we hope to bring in a future update, see The features we are working on right now…
Edit the name of each project and place a 1, 2, 3, etc in front. Then you can order the projects in your preferred order (albeit you’ll have an ordered number prior).
I would like to see project and category moving as drop down options. Better still to be able to locate a project from a dropdown in the central pane and be able to drag-drop it to another category in the sidebar.
FWIW it is easier just to create a new project in the newly desired location and then share your notes out via dropdown move to, drag-drop, and export.
