Agenda cannot handle 600 notes? That seems like a low limitation.
What do the developers recommend as the maximum amount of data stored in Agenda? I wouldn’t know how to “split it up” since it seems Agenda’s database is “all or nothing” at present.
Hi,
I have the same observation. The memory consumption is slowly increasing even if I do not work with Agenda and I am just browsing on the Internet. It roughly 0,01Gb increases every 10-15 minutes. It affects the smoothness of the UI elements as well. The elements are slow, and scrolling is lagging as well with higher RAM consumption. I would love to have that resolved rather sooner than later. It could affect my decision of purchasing the app again.
If there is something you would need from me, please do not hesitate and contact me.
Thank you
I just updated to version 9.1 from the App Store. Agenda is continuously using 200% CPU and increasing its memory usage - already up to 18GB in just 10 minutes of usage after updating. I’m not doing anything in the app. Just before the update I was prompted by the system to quit something because the system had run out of memory - and Agenda was using 100GB.
I started up Agenda again and within 3 minutes it was using over 3GB - with Dropbox sync enabled.
Then I turned off dropbox sync, quit Agenda and started it again. After 3 minutes it was remaining stable using 190MB of memory and 0% CPU.
Third I turned on Dropbox sync again (without quitting Agenda) and signed into Dropbox to ‘Allow’ access. I let it run for a couple of minutes and then restarted Agenda. In both cases, after turning on Dropbox sync again, Agenda behaved well, only using a max of about 10% CPU, often less, and using about 300+/-50MB of memory.
So it seems to have fixed itself after disabling and then enabling dropbox sync again.
BTW on a dropbox-sync related note, Agenda on my iphone wasn’t syncing with dropbox, and I had to delete the app and reinstall to get it to sync again. This has happened before as well. Seems to be syncing again now.
I’m afraid there are still issues with Dropbox sync. Some are difficult to fix from our side, such as rate limiting of uploads. They have very low limits, making reasonable sync more difficult.
We have some ideas about how we may be able to improve things, but they are not quick fixes. If you have the option to use iCloud, I strongly recommend it.
