It turned out that Magnet (third party window tiling app) was sometimes truncating my notes (reported here.) I reported the problem to but have received no response.
Moom is a similar app. Does anyone know if it works properly with Agenda?
I frequently need to have Agenda on half my screen and another app beside it. The native Mac way of doing this is a total pain. Magnet is wonderful apart from truncating notes, forcing me to faff around with Agenda to see the full note again. I’d love to find a working alternative!
But… this seems to be an Agenda bug though, since it can also be reproduced using MacOS fullscreen tiling features. Although I can’t think of any other app I’ve installed that shows similar problems using Moom.
Please see how the first note is selected when Agenda gets fullscreen maximized. You can spot additional space that’s get added to the note below the image (this additional space gets added to all notes btw.).After leaving fullscreen, the note(s) get truncated. You can see this, because the image is not visible anymore.
Hope that helps,
Markus
P.S. I can provide you with a link to the full resolution video on request.
Alas, no progress, it has to do with how magnet resizes windows, apparently in a way that it doesn’t trigger the regular updates that happen when you resize manually. We have some things to look at that might or might not be related, so perhaps it will get fixed alongside those, but to specifically investigate issues with 3rd party windows managers doesn’t have as much priority as other issues I’m afraid.
I have good hopes I have made some changes that fix this as part of fixing an issue where going in and out of fullscreen mode would also truncate notes. Make sure to test the 13.1 update once it’s out in combination with Magnet and let us know if the issue still arrises.
@trebso@markus we found and solved an issue in Agenda 14 with the notes width not updating when resizing the Agenda window, this might very well also solve the issues you’ve been seeing with Magnet, would be be able to see if that’s indeed the case?
