Keboard Shortcut for Checklist (tasks)
I have to manually add a checklist by clicking the radio button and adding it from the drop down menu. Is there a keyboard shortcut, I cannot find the same in the menu bar items.
the shortest keyboard shortcut for checklists is
-[] words
You have to start typing your words after the Space to make the checkbox appear.
see here
There is also a keyboard shortcut: CMD-Shift-C. Having said that, I believe that shortcut will change in the very next release, so perhaps better not to get too used to it.
Quick update: we decided to keep the shortcut the same in order to avoid collisions with others.
cool. Like the shortcut
