How to sync Mac data with iPhone without iCloud?
I have iOS (Full features) as well as Mac version with full features purchased.
iPhone has iCloud enabled. However, MacBook does not as I don’t want use iCloud with mac.
I have a lot of data & files on iPhone and want to sync with mac app.
I would not locate sync features. Thanks
Hi!
You can also use Dropbox to sync. I’ve not done it, but you should find instructions on the forum.
Indeed, Dropbox is the alternative sync solution we provide at the moment. See Stay in Sync
