How to create a template + automation to create a new dated note for next 31 days?
I want to populate a Project with one Note for each weekday of the coming month - with each Note assigned to the relevant date. The title of each note will be the same.
How could I set up some combination of Template and Short Cut automation instead of doing this manually?
I only want weekdays, but at least for the first version of this, happy to create one note for each day, and then manually delete the weekend notes.
PS this is for my content calendar.
I’ve moved the discussion to the Shortcuts section of the community. As you say it’s probably something you want to do using Shortcuts/x-callback-urls using the template option/call. I’m not the best person to show exactly how to setup the Shortcuts app but perhaps others can chime in.
