Hierarchically Organise Projects
Hi,
I tend to organise my notes hierarchically in the sidebar. Wondering whether there is an option like that in Agenda
Screenshot from Bear below:
SCR-20230811-iyvo
Yes, you can achieve a similar hierarchy using subcategories, see Get All Features
The picture in the original post shows 3 levels personal/interview/rounds … is it possible to achieve 3 levels using subcategories ?
I believe subcategories are infinite
thanks - I was looking at it wrong, trying to create a subcategory off of a note instead of the category.
