Typed a string of text into a note on ipad
Text registered and displayed several seconds after being typed. Some times, when backspacing it will go on and backspace infitinitely until everything is deleted.
For me to type normally into a note.
Hunch:
This behavior has started ever since i copied and pasted formatted text from an external source into the app on my ipad.
I am facing the same issue on my iPad Air 2… Agenda is very close to be unusable on the iPad.
When turning off iCloud-Sync I also had to go offline and restart Agenda several times before Agenda behaved as expected with iCloud-Sync disabled. Is this a known bug?
Willing to test a beta using TestFlight…
Hi Drew!
Every keystroke is slow… but not only the keystroke but also refreshing of the Agenda-UI is slow. Even refreshing the keyboard within agenda is slow (the small popups when pressing a key stick for a second or even longer).
Turning sync off did make everything work as expected again.
Stefan
Playing around a little bit with this issue it is not yet reproducible 100% but happens very often… workaround is to disable iCloud sync and give iOS some time to “calm down”.
This issue happened again after one day for me. so not an acceptable workaround.
Btw it is not iPad alone, also happens on iPhone X (which has even more computing power).
Have you tried a reboot of your devices? I’ve seen this once and it got resolved by restarting my iPad, apparently something was blocking iCloud or driving a lot of CPU usage. Never really found out what was causing it.
@greiggy is this in large notes, or just after you have brought the app to the foreground/started it a again? The keyboard disappearing could indicate that it’s due to synced data coming in from another device.
I have no really large notes. There’s one I refer to and add to frequently and the keyboard sometimes disappears when I bring it up. It is kind of medium length…
Can’t tell how many words or characters it is – would be good to have this shown somewhere ;
We continue to improve the performance as we go, as we’ve done in almost all updates. There’s no silver bullet though, so it’s unlikely that we’ll fix it in one particular update.
