Default templates per project/ category/ sub-category
Templates are a great feature in Agenda. However, there is no provision to set a default template per project (or per category or sub-category).
I have created default templates for most of my projects, and it is frustrating to click the + button, and then realise that I needed to click/hold the + button to access the templates sub-menu.
I always end up creating a note, then deleting it immediately and then follow through with the correct template.
I am assuming this has been requested before as a template feature; as it increases template usability multi-fold.
In the meanwhile… provide some shortcut key to open the template submenu… (simulate the click/hold + button)
Cheers for the feedback, it would indeed be nice to set a default template per project, category, or even the entire app.
Regarding the easier way to trigger the template submenu, keep in mind it’s also directly available under File → Add New Note from Template…, and you could even consider adding a specific keyboard shortcut to any of these using this trick: Keyboard Shortcuts Overview
Does this offer a solution, or at least a path?
Tried it. Doesn’t work :frowning:
Any update of this feature?
Not at this point. Thanks for bumping it. We’ll take it along.
