Hi,
Again great app. While I am writing notes and doing monthly reflection, is it possible we can have a function that allows us to comment on a specific line or certain lines?
All the best
Hi,
All the best
Thanks for the feedback! Weāll take it on board.
For now, I would recommend perhaps using the new block quote functionality. It indents and adds a line, and looks a bit like a comment, so maybe a good workaround for now.
Another option, I suppose, would be to write a comment in another app (eg TextEdit), and drag the file into Agenda. It would appear as a thumbnail, and you can read the comment by opening the thumbnail.
Iād really value the ability to add comments to words and sentences.
I often have complex emails that I need to really think about before replying, or creating a proposal in response etc. I import these to Agenda, because itās my āthinking spaceā.
I like to go through the email in the note and add comments, questions and ānotes to selfā.
I can then open a new window and create a new note to draft my response or proposal while reading the comments.
Iāve tried using block text, highlighting and code, but theyāre all pretty clunky, especially when trying to comment on specfiic words or short phrases, rather than a whole paragraph.
Just as a suggestion on this topic.
I have made a note of this topicā¦
ā¦because there are some very interesting approaches and ideas. I also find the āOpen link in new windowā function very useful.
Same types of ānote notesā needed here also. For the most part, Iāve been creating a separate footnote for each reference represented by a superscript letter / numeral which is also the note title of its content . r1.0 =reference, c1.0 =comment and for definitions the word or phrase is an in-line link. When needed these content also link to proper ref material. Iām planning to consolidate this system into a 3 project sub-category covering all projects and notes for the category. Doing this in a separate window is a lot better.
This would be a breeze with paragraph level granularity and a beauty with link mouse-over previews.
Definitely an interesting approach for more structured notes like references and footnotes that I might definitely use in some circumstances.
But too clunky for my need to capture fleeting thoughts and ideas as I read a text.
Thanks for the feedback! Weāll take it along
I got curious about the notes on notes thing so I tried a few. Apple Stickies actually arenāt that bad, at least worth not totally forgetting. Iāve got an app called Side Notes that I bought for a similar reason before Agenda to use with whatever app I was working in. Its use anywhere is handy but for what youāre describing it doesnāt feel integrated. What does work is the comment pop-up in pages and numbers, itās great. A similar feature for Agenda would be a very useful addition.
