Creating a list with (-). The list item I wrote includes text in 4 to 5 raws. I use the internal ipados keyboard.
After a while when I start to edit the text or add more list items the whole list with items seems to be copied and pasted randomly many times after each other. Sometimes Agenda copy the text of an list item and paste it randomly many times after each other. Sometimes when scrolling the bug extended list ups and down the list gets more normal in size of items but the text of a list item that was pasted randomly many times after each other are still there.
That Agenda itself not should copy and paste text randomly outside my control.
Agenda 20.0.1 IpadOS ipadair 5th gen.
This also happened to me on my iPhone. I donât remember exactly what I did, but it happened after I tried to edit a note shared for collaboration. I remember deleting this note as a solution to the problem.
Now I tried to copy the list items and created a new note to paste the text. I deleted the old note. The problem has not occured yetđ.
When â:â are used itâs a good way to create emojis.
The old note had many â:â in the text, but not for creating emojis. I tried to deleting all â:â to avoid problems Iâve seen before when using â:â.
The internal iospad keyboard behaviour I seen before when using â:â sometimes leads to an awful slow and buggy Agenda. Sometimes when it happens the cursor is unpossible to move with the space-button in the text. After that the cursor go bananas all over the text and sometimes it paste text randomly many times again and again.
Maybe the problem sometimes occurs when using â:â in Agenda note text?
We did have this in the past, and thought we had fixed it.
It can happen if somehow there is a new line character (return/enter) embedded where it should not be, like in a link. If you can think of what might have gone wrong in your case, let us know. (A new note is a good solution though)
Iâm not sure but maybe the filter text option fool me sometimes. If you donât keep an eye on paragraphs and the small icon button they will fool you not seeing if the text is filtered or not.
Anyway if this is the problem or not it would be an improvement to have an easy-to-read button or text below the note text that has not been filtered that indicates that note text is filtered.
As it is now the only way to see if the note is filtered is the icon button .
Yes, the arrow button, but also the yellow text at the top under the project title. Itâs not on the note itself, but is intended to be quite visible (hence highlight yellow).
Weâll think about it. Itâs a balance between seeing that something is filtered, and cluttering the note with lots of indicators or controls showing where pieces of text are hidden. It could get quite messy if we arenât careful.
I was working on a note and I remember that I copied text from my wikipedia app to the note with included link. I used the function âlink to textâ. I kept on editing the note and 10 minutes later this happen:
The random text is the other text duplicated, is that right?
This is a bug, but a link should never have a new line in it. We should be checking for that, and we did add code to do it, but perhaps we missed something.
When I started to edit and divide the text by adding own text block marks as âTB1start, TB2stopâŠTB13stopâ the same thing happens again with that text. Randomly pasted text everywhear and also text that was (visually) changed temporarily (same line with text after each other) but now I canât see them.
Just to confirm: does this all happen in that one note with the link? If you start a completely new note, does this same problem arise, without the link?
Itâs a good question. Iâm not sure but from now on Iâm going to create new notes without links. Ofcourse I will give you feedback about that.
I copied the text (no links in it) from the old note to a new note. At first there was no problem. I started to editing and adding new text to the new note. Once again i copied text from wikipedia that included a hyperlink. The hyperlink itself wasnât of interest so I used âlink to textâ. I think the problem arised after that.
Before paste links into Agenda is there a way to choose between a âgoodâ and a âbadâ link?
New feedback. It happens again with NO LINKS INCLUDED.
What I did: I pushed the button to use function âone window for the actual noteâ (at the end of the note with two cards lying on each other . To the right is the note setting button.).
Then I pushed the âno filterâ text button (the button with two arrows) to see all text in that note. Lots of copy and paste text blocks added everywhere as before.
As it is now I canât use Agenda because of that bug. Itâs too irritating for me.
Itâs very strange that it seems like Iâm the only user with this problem, isnât it?
Itâs so weird. 2 hours ago I sent feedback about lots of text blocks everywhere. After that I closed my iPad (not turned off) and now everhing is fine again except a few bug rows with text.
The note is a list of difficult words and the meaning of them. Itâs intro text and then a list in alphabetic order. I did a copy as (I choosed text).
The result is below with added text (text)
SvÄra ord
Intro
Innan jag bröt min armbÄge sÄ kunde jag inget av dessa ord och definitioner. Inga lÀnkar i denna notes.
Wrongly Pasted text
Extension=StrÀcka en led sÄ att den rÀtas ut.
Wrongly Pasted text
Flexion=Böja en led, vad gĂ€ller en armbĂ„gsled Ă€r det att âspĂ€nna överarmens muskelâ.
Correct list in alphabetic order
Aktivt rörelseomfÄng=Det rörelseomfÄng (som anges och mÀts i grader) som du kan ta ut i en kroppsdel/led pÄ egen hand. Man anvÀnder enbart kroppsdelens egna muskler för att tÀnja eller dra ihop en led. Ingen yttre kraft anvÀnds. Motsatsen Àr Passivt rörelseomfÄng.
Distalt=Anger en **riktning som **Àr frÄn överarmen till handens fingerspetsar via underarmen. Copied text
Extension=StrÀcka en led sÄ att den rÀtas ut. Copied text
Ledfunktion=RörelseomfĂ„ng=Hur mycket en kroppsdel/led kan röra sig mellan olika Ă€ndlĂ€gen (exvis mellan extension (X) och flexion (Y)). ĂndlĂ€gena mĂ€ts och anges i grader (âX grader-Y graderâ). Exempel) ArmbĂ„gens ledfunktion Ă€r (0-150). Vid rak arm sĂ„ Ă€r den 0 grader. Underarmen kan sedan röra sig 150 grader uppĂ„t.
Luxation=Att benen i en led förskjutits, vilket försÀtter leden ur led.
Mobilisera=Passivt rörelseomfÄng=Man anvÀnder en yttre kraft för att tÀnja eller dra ihop en led (kroppsdel) med mÄlet att öka rörelseomfÄnget. Det Àr oftast en sjukgymnast som bidrar med den yttre kraften.
NeutrallĂ€ge för hand/arm=En position dĂ€r kroppens framsida visas dĂ„ handflatan och armen vilar mot kroppens sida, med tummen lĂ€ngst fram. Om bara överarmen vilar mot kroppens sida och underarmen böjs sĂ„ att vinkeln mellan över- och underarm blir 90 grader med tummen âlĂ€ngst upp av fingrarnaâ och den positionen kallas ocksĂ„ neutrallĂ€ge eftersom handen inte gjort nĂ„gon egen rörelse nĂ€r underarmen lyfts upp.
Passivt rörelseomfĂ„ng=Mobilisera=Det rörelseomfĂ„ng (en vinkel som mĂ€ts i grader) som du kan ta ut i en led (kroppsdel) med hjĂ€lp av en yttre kraft. Man kan exvis anvĂ€nda den yttre kraften för att tĂ€nja eller dra ihop en kroppsdel/led. Motsatsen Ă€r âAktivt rörelseomfĂ„ngâ.
En rotationsrörelse inÄt gentemot kroppens medellinje.
Proximalt=Anger en riktningfrÄn handens fingrar till överarmen och axeln via underarm och armbÄgsled.
RörelseomfÄng=samma som __Ledfunktion __
Supination=Det avser inÄtrotation av en kroppsdel. Supination pÄ handen Àr en rörelse dÄ handflatan vrids nedÄt frÄn neutrallÀget (=0 grader). Pronation 90 grader=Handflatan Àr helt nedÄt.
Suturer = de stygn som lÀkare, sÀrskilt kirurger, anvÀnder för att hÄlla samman hud, inre organ, blodkÀrl och annan vÀvnad i den mÀnskliga kroppen efter en olycka eller ett kirurgiskt ingrepp.
Traktion= Metoder för att strÀcka eller avlasta i ett skelettsystem.
Triceps=En muskel pÄ överarmens baksida som ser till att armen kan rÀta ut sig.
Ulnart=Anger en riktningmot (i nÀrheten av) lillfingrets sida vad gÀller hand och underarm.
For me the priority will be to use agenda without any extra options. Itâs ok for me if the bugs donât arise again. If the bugs arise again I will unfortunately temporarily stop to use Agenda and do the work in another app.
The first try will be to delete text filter option from the project AND not use any Focus mode windows at all. Links will not be allowed in the text.
In the future I will give you feedback if bugs are there or not.
