Could Agenda supports absolute and relative links to local files? And to files stored on iCloud?
So far with Agenda 1.4, I am able to drag a file to a note which will create an absolute link to it (file:///Users/…). If I click on the link, it opens the folder where the file is and not the file itself with the default app. Can this be changed?
Could the link be also relative so that it is not related to a specific user (use of ~)?
It should still work, which links from which app are you dragging? Note that you need to be editing the note that you’d like to drop the link into or it won’t accept it.
