+1 for manual re-ordering of Smart Overviews
Hi – just a small suggestion/request! :slight_smile:
Thanks for the feedback!
The topic here is definitely part of it and will make me happier in Agenda.
Yes, that is definitely in the roadmap. Probably would do these two together.
Hi. You could also just allow manual reordering of notes within Projects while you are in there. I know this is a classic request, but I have enough notes in this thing not that it would really be helpful. Thanks.
Not following. You can manually order notes already. There are restrictions though related to notes with dates. When notes have dates, it will keep those ordered chronologically. But if you have notes without dates, it should be possible to move them around.
You can’t order in a Smart Overview though, because they are more like searches, not actual lists. We would have no way to know how to order things when the search result changed.
