agenda://x-callback-url/open-note?identifier=8A1EAE96-2A8A-49BB-BC87-CF96BE991060
works in Mac and iPad but not on iPhone.
Is there something else I need to do?
And the respective note is present on the phone correct? We’ll verify what’s going on
Thanks. Yes, it is.
I should explain more clearly: on iPhone, the link opens the Agenda app at the last viewed note; it doesn’t display the required note.
I’ve now found the link from iPhone works if I add &separate-window=false to the end of the link, so that’s fixed for me. Strange that it’s needed for iPhone but not iPad or Mac.
Indeed, and it shouldn’t be needed, but you did point us perfectly to where the problem is, we’ll fix that! Thanks!
Update: this should be fixed in Agenda 19
