Hi,
I have a “large” widget on my desktop in MacOS with Eligible Notes set to “On the Agenda”,
but the ordering does not mirror what is shown in Agenda. It seems arbitrary.
Is there any way to fix that?
Thank you!
Hi,
Thank you!
The widget doesn’t show all the notes in On the Agenda. It takes the notes from On the Agenda, and prioritizes them based on the date they have, and other aspects. It tries to pick out the most relevant notes, but that will not always be perfect.
You can create widgets for your favorite notes, if you use particular notes regularly.
We may look into allowed some sort of primitive scrolling in widgets in future, but TBH at some point you hit diminishing return, and can better just open the app.
