- synced to iCloud
- Used the doc scan feature
- Navigated to iCloud
- Sorted files by most recent
PDF scan did not appear
PDF scan to appear
Agenda v21.1 | macOS Sonoma 14.6.1
When you scan in Agenda, you should end up with a document (PDF) inside Agenda. It doesn’t scan to iCloud, it scans to Agenda.
Did that not work?
Yes. It does scan to Agenda. My understanding was that, when synced with iCloud, that the files would be stored in iCloud.
They are stored in iCloud, but not in a place you can access. iCloud is just used to sync data between devices. You have to access the PDF in Agenda, though you should be able to share it to the Files app to get it in iCloud separately.
Fascinating! Thank you for the explanation.
