I guess this is for the Apple Intelligence, right? Good to know. Thanks!
Apple interllgence +1
However as an data science student, I will be also really want to get the katex support also, if it is possible. As it seems more easy to implement for additional support
I often use Linux as well as the Apple ecosystem and so I would love to see a web based version that I could then use whatever the platform. I think this would make a good premium feature.
The problem is more that we would have to upload all your data to make such a version. I guess it may be possible to just upload a few projects or something like that. Thanks for the feedback!
A task isn’t a cal event. Latest iCal and Fantastical can handle a todo. I was going to request a few changes that would let users enter todo info that will work in/with the Event entry panel. Unless I’m just having a really bad day, the panel with the start-duration-due selector is now missing so you have to use the reminder app ui for any thing other than an event. I can’t tell you how much I dislike using that app. It also eliminated my script going to OmniFocus for tasks and todo list for the daily notes!!!
Do you mean the Event entry panel in Agenda? I don’t see it either - but I don’t think I’ve ever used it, so I don’t know if it was ever there.
If you mean the Reminder entry panel in Agenda, this is what I see:
But I don’t think there’s anyway to create a Reminder with a duration - unless there’s a workaround?
