What’s next for Agenda
I just renewed my license and I’m wondering what features you are working on next. I’m hoping that it’s integration with Apple Contacts.
I’m loving the text filtering in Agenda 20. Great work!
Thanks for the encouragement! Appreciate it.
We are considering a bunch of things for the next update, and contacts is certainly one on the list. Can’t promise anything yet, but your request bumps it up a bit! :smiley:
Please add another request for integration with Apple Contacts.
:white_check_mark: Calendar
:white_check_mark: Reminders
:x: Contacts
Feels like Contact integration is a local next step!
Would love to see this - being able to have a task like: “Call Jo Bloggs” then clicking on the name and being taken straight to Jo’s entry in the Apple Contacts and dialing from there.
Also, related notes panel showing other notes including Jo Bloggs.
Yep, makes total sense, and is very high on our list.
Hmm. What about integration with Mail.app on Desktop?
Can you be more explicit? What integration would you like?
One problem with Mail is it has no share sheet. I have no idea why. So it already starts off from a point of not integrating very well.
What you can do is drag a message into Agenda to get a link to the message.
Let me know what other ideas you have.
Thanks.
That works when I drag into a new note.
Looks like the mistake I was making was not selecting the note in Agenda before dragging in the email.
Right. A note does have to be selected, because that puts it into editing mode.
Glad it worked out! Let us know if we can help with anything.
I’m another one to add to the Contacts integration. It completes the circle for me with Agenda, and also means I can finally retire my Newton and upgrade my Mini to a new one!
I like to track customer notes against visits or calls (Calendar) and link back to the customer (Contacts). Reminders to action something for the customer or project deadlines.
Scribble on the iPad is excellent now and can replace my Newton.
Thanks! I see a trend here :slight_smile:
Yes, Contacts integration seems like a slam dunk. Been on the list since the beginning, and fast approaching the day where we need to add it. Agreed!
Hi - On Mail.app opportunities: it would be great to able to drag an email on to a specific date in the Calendar Panel - This action should create a new event with the email subject being the event title and the URL link to the email being embedded into the notes section. Or even better pop up an card allowing selection of create - cal event, reminder or note
At the moment I either have switch out of Agenda into Calendar App to embed a link into Cal event or Create a note in Agenda, embed the email link into that note and then create an event linked to the Agenda note.
This is a workflow I use a lot as Mail.app doesn’t have a proper snooze feature. It feels ripe for a simplification of the process.
It seems like a bit of an obscure workflow. I haven’t seen that before.
Perhaps you could create a shortcut for it. That might be a better approach, because I’m not sure there would be a lot of people using it, given it involves 3 entities (note, event, email).
Thanks for the feedback!
Hi! I’m not sure if it’s already in the pipeline, but I’d really love the ability to create calendar events from to-do items in notes and choose which calendar to add them to.
Thanks for the feedback! It’s a bit outside the design of Agenda, where we link at the note level to events. Eg. create a note for a particular appointment or meeting.
Inside the text, we support embedding of reminders, which would seem to fit better with a to-do item. You can set a due date, just like a calendar event, and have as many reminders as you need per note.
Hope that helps!
And now that Apple Calendar supports Reminders, you can set a time for the reminder to show up in the calendar alongside events (with a link back to the note).
It’s a pity Reminders don’t have a duration though!
A reminder with a duration would be a calendar event with an alarm :stuck_out_tongue:
Seriously? :roll_eyes: Making the duration functional (ie; any 2 variables complete the 3rd) is in my event and todo panels request list, coming soon to an inbox near you.
What if one had a problem presentation with a solution discussion to schedule followed by a meeting soonest afterward? It’s easier to work out a max discussion duration for negotiating the meeting window.
True-ish! Except there’s a sequential issue here:
I might have a Task “draft web page”, I estimate it will take one hour, but I don’t know when I will do it. A calendar event requires you to fix a time to do it.
FYI, iOS 18.4 beta 1 dropped today, and the EU region lock has been confirmed to have been removed. When you install it, note that things may seem to be unstable for a few days as new models are downloaded, semantic indexer runs etc.
