Is it only for Safari or is there a Chrome one as well?
For this first version it is a Safari extension only, on macOS. We would like to add Chrome and Firefox down the line. We use Safari’s WKWebView under the hood for the clipping bit, so a cross-browser version is a bit more work, but it is on the list. iOS and iPadOS Safari extensions are also something we are looking at.
Is it possible to access the extension file directly via the Finder? I have discovered that it’s possible to use Safari extensions in the Orion browser if you can navigate to the extension in the Finder.
(Reposting in a more suitable thread)
The extension is bundled inside the Agenda app. If you right-click Agenda in Applications and choose Show Package Contents, you can dig into Contents/PlugIns and find the Agenda Web Clipper appex in there.
I do not know if Orion can pick it up that way, since Safari App Extensions are signed and tied to their host app, but it would be interesting to hear if you get it working.
