Video Tutorials
Agenda now has a dedicated YouTube channel we call “On the Agenda”, where we regularly post videos on how to use and get more out of Agenda. From walkthroughs, to tips and example, to discussions with fellow Agenda users.
Every time we post a video we also create a corresponding page in the On the Agenda section of the community. Here you can find the latest videos and a place for each to discuss and ask questions.
Visit the Agenda YouTube channel for the latest video tutorials, tips and examples.
What is Agenda and why should you use it?
Agenda allows you to be in control of the many things going on in your life and stay on top of everything important to you. It helps you become better organized and more productive. In this video from our Agenda YouTube channel we explain why Agenda is date-focused, the way achieves all of the above, and how it works:
3rd Party Tutorials
Below you’ll find a selection of 3rd party video tutorials demonstrating how to use Agenda:
Video Reviews
Agenda is frequently featured in note taking app reviews, below you’ll find a selection of these:
These videos/reviews are kind of ancient.
We’re indeed looking into making new ones ourselves, stay tuned!
Consider making some advanced / power user totorials too.
Definitely, that’s indeed what we have in mind as well.
I have had (and paid for) Agenda for a while now, but just can’t seem to get to grips with it. I don’t understand how I can fit it in my workflow, as I can’t easily understand how Agenda is supposed to work / meant to be used. I don’t have the time to read loads of posts about individual features and updates, and feel there’s a real lack of useful, practical video content that clearly demonstrates how Agenda can be used (and how it justifies the cost).
Maybe it’s just me, but I just don’t seem to be able to “get” Agenda.
I’m hoping a really good video tutorial will explain exactly how and why I should be using this app — 'cos at the moment, I find that I’m not really using it!
You’ll be happy to hear that we’re working on these as we speak! Stay tuned, I’ll post here the moment they become available…
Any update on those videos?
I’m afraid I still don’t understand quite how I’m meant to use Agenda; what it is supposed to do beyond any other markdown editor; or how it might fit in my workflow. I see mention of ‘new features’ but can’t really see why they’re included or how they’re useful.
Maybe I’m wrong but, despite its name, Agenda does not appear to be for making meeting agendas, right? It seems to have to-do list features, but is not a task manager, right? I can take meeting notes using it, but we do this on GoogleDocs, as meeting notes are shared with our team. Does Agenda support team sharing of such ‘notes’ documents (or whatever Agenda files are called)?
Agenda puzzles me considerably. I admit it is very beautifully designed… but I just can’t figure out what it is for — or precisely how it might be useful to me…
I am new to Agenda, I used Notion (organisation/notes taking app) for 2 times and I gave up
Agenda is cleaner and less complicated with better visual division between notes in the same category. I still need to learn to unlock much of its potential though.
hope I can learn how to add date and then sync to my calendar with time (when to when).
For intro material, see our you tube videos.
The How To pages give lots of info about different aspects of the app.
To link a note to a calendar event, select the note, click the calendar icon top-right on the note, and select the event on the right of the panel. Then press the link button. Done!
A year later — Any update on those videos?
Thanks.
Video help page: Video Tutorials
YouTube page: https://www.youtube.com/c/AgendaApp
Agenda - A modern version of the Franklin Covey Planner & Trapper Keeper (AKA 3 -ring binder) & Palm Pilot all rolled into one only much Much MUCH better!
Almost, almost… When the integration with Contacts arrives it will have PalmPilot functionality!
I am with Demonstrable. I have agenda, but I don’t get it. I am working my way through YouTube videos on your channel, reading individual posts here in the community, reviewing the samples that come with the app, and struggling by starting a few projects. But, it’s not coming intuitively. what kind of help do you have for someone like me? Is there a PDF that explains the main screen functions, or suggestions on how to use?
Perhaps worth reading through the help pages here: How To - Agenda Community
(You can also access them in Agenda using the ‘islands’ button)
To get started should be straightforward:
  • Create a project on the left using the + button
  • Edit the note in the project
  • Add another note using + at top
  • On the right is integration with calendar and reminders. Connect that.
  • You should be all set to write your notes.
The main difference between Agenda and other note taking apps is it has a timeline for each project. Your notes are effectively in chronological order, with the newest at the top. It works best for anything that progresses through time, which is why we call them projects.
Hope that helps!
Yes, that helped a lot! Thx.
