Vertical Scrolling
Will there be some kind of vertical scrolling any time soon? Would love to see notes separated vertically than having to scroll down
The Agenda timeline of notes is unique to the app. We are unlikely to change that aspect.
What you can do is click the button at the bottom of a note to get it split off into a separate window. It will then behave more like a standard note taking app, with a single scrolling note. That is probably the best bet.
