trebso
January 5, 2023, 10:52am
#1
tried to use [[ to add a link in the middle of existing line of text
the pop-up only offered to create a new note with the title {rest of my sentence}
option to link to an existing note
Version 16.1 (263) - Mac App Store
I’ve often been bit by this.
We’ll take another look but from what I remember this is a trade off between allowing multiple word project and note titles to work with autocompletion vs working mid-sentence. The latter has a higher priority for us and mid sentence completion is still an edge case compared to end of the line completion.
trebso
January 5, 2023, 4:28pm
#4
Thanks - and I agree with your priorities here if both aren’t possible.
This post describes a number of workarounds btw if you want to create links in the middle of sentence:
There are a couple of workarounds actually.
You can limit the scope of what is considered the search query by typing the two closing brackets. This means that you could either:
type immediately [[]] and then move the cursor in between the brackets to type what ever you want, or,
type the opening [[ then the query like “Alex”, followed by the closing two brackets, you will then search for just the word “Alex” in the note titles.
The first is probably easier if you’re not sure what to l…
