Can I use this MarginNote 3 addon URLScheme function to automatically add excerpts to Agenda?
I was wondering if the variables would work with x-callback
Thanks for the suggestion, weâll take a look
I managed to do it. You can delete this post because Iâll soon (when I have some free time) make a âguideâ, based on my experience, on how to use agenda for your productivity and how to use agenda and marginnote 3 for studies (using x-callback and this plugin).
I hust have one question.
Is there a way to add new lines when using append to text function?
For example:
agenda://x-callback-url/append-to-note?title=Studies&text={{allText_h}} (return key for new line)đ{{link}} (return key){{tag_h}} the stuff between keys are the mn3 variables
Hmm, I think you would need to enter \n and then use percent escapes on that. Seems like the encoded variant would be %5Cn
Not tested this, but I think that would be it.
Thanks Drew!
