I recently noticed that I in the app settings for Agenda can choose Synology Drive as a storage location. Does that mean that my notes gets saved in Synology Drive or just attachments? If it stores notes in Synology Drive, does it then work?
I don’t think that will be very useful. For sync purposes, we use iCloud.
I think that setting is just an option to store exports/imports (documents), which aren’t used that much in Agenda.
Okay, thank you for the quick answer. Would have loved an option to sync with WebDav or similar then so I could store my files on my NAS instead of a cloud service.
We will take it along.
Note that the sync data in the cloud is not human readable, it is designed for the devices to sync. So it is not very useful to have a copy of it to edit.
Also I would like to have an option to store my data in my NAS. I would like to have as much data on the same place. That is my NAS.
