Use Space in Tags
I tried to add een “@“ tag with “ALEX L”. but what happened: the tag was limited to “@ALEX” while I expected: “@ALEX L”.
Then I right-click on the tag and I was able to modify the tag to “@ALEX L"
What is the option to do it in one step? Shift/Alt/Ctrl “space" does not do the trick
Yes, use brackets. Like this @(Drew McCormack)
