Hey there guys, at some point in life I stumbled upon Agenda for notetaking. I use it all the time. I would like the ability to turn off automatic URL renaming so that I can actually see the URL. This would be super easy as a setting that you can check On or Off system wide. The problem is that sometimes, especially if its in a foreign language, the shortened version will show something I don’t understand and doesn’t make sense, so it doesn’t stand out. I realize I can go back and highlight and then use CMD+K on Mac to then select whether to show full URL. But this is a slow work flow when dealing with large amounts of links.
Would love to see this option.
The easiest way is to type a backslash character (\) before pasting the link, it will then keep it as is.
nice tip to stop this from happening, but having a default behavior would be an improvement - JIRA cards, other short URLS from internal directory that mean a lot and are preferred - using an app specific trick, which if every app defaulted to this behavior, increases cognitive load - huge fan of the app and tell others to use it
as an aside, not a huge fan of agenda hitting up a site to get what is believed to be a correct name, even if a short round trip - many apps that replace URLS with some content from the site provide an option to stop this from happening
keep up the good work!
