I read one of your articles about how searching and building indexes and all is hard — and I used to write software — so I’m pointing out a problem that floored me a bit but I get that there isn’t an easy fix.
Background: I’m part of the chronic illness community online and have a friend that has a medical device I’ll call a v-gram (making that up but it’s a similar sort of word). She asked me if I remembered something about the history of it, so I tried searching Agenda to answer.
What I did: Search for “v-gram” in Agenda.
What happened: I got matches for all words that started with “v" and all occurences of “gram"
What I expected: for “v-gram” to be treated as a word, so only instances of “v-gram” be found
Things that might be helpful to know (Agenda version, OS and model, etc): Agenda 14.0.4 (224); Mac OS Monterey 12.3.1; MacBook Pro (15-inch, 2018)
This was disconcerting because I had about a zillion matches and couldn’t easily find the ones I wanted. Thankfully, my friend could find the information elsewhere. I thought about what I could do to make it easier in the future; maybe change all instances of “v-gram” to “vgram” or a hash tag but even then I’d have to actually find every instance of “v-gram” in order to change it, and I’m not sure how to do that easily.
Something to think about? Thanks & take care!
