Understanding To-Do's
Hi all - coming back to Agenda after a couple of years. The current version is terrific. Signed up for premium. All is well, but I can’t figure out how to efficiently use the To-Do’s. I have a note that shows up in there and can’t remove it (unless I fully delete it.) I’d like to take notes, then perhaps select a few items in the note, such as an end of meeting takeaway and make it a to-do. That should show in the to-do list and link back to the note. When I check off that to-do, it should be removed or crossed off in the to-do list. Added, I’d like to just quickly add a to-do as a reminder.
No one app has every mastered this combo. From Monday to ClickUp, OneNote, OmniFocus… one is great on to-do’s and weak on notes. One is great on notes and weak on to-do’s. Opportunity here for Agenda to meet that need.
Thanks for any info!
Here how I deal with Todos:
  • in any note I want, I transform any line in Todo if it needs an action from me.
  • In the Overview To Do, I filtered the content to see only Unchecked Todo (this is a new feature from Agenda 20).
  • In the Overview, I see only the unchecked to do lines from ANY notes of ALL projects. I see the notes in the chronological order (like in Agenda view) but I don’t see anything else than the to do items inside the notes.
  • When I check in this to do Overview OR inside the notes themselves, the item disappears from the Overview.
With that system, I’ve got a complete list of my undone tasks, grouped by the notes where they are from (aka projects).
This system fits perfectly for me.
Great. Thanks so much. Seems a little tricky to me creating a to-do however. How are you ‘transforming a line’?
To create a to do, select any line and choose Format > List > Checklist, or use the SHIFT-CMD-C combo.
On Mac you can also click the little button to the left of the paragraph, and choose a checklist in there.
On iOS, select the paragraph, and use the keyboard bar to change it to a check list item (todo).
Brilliant. Thank you.
Consider with the + under the To Do section, in future versions, incorporate an “add To Do”
Sometimes you just want to create a reminder / to-do that’s not a note
And my favourite: simply type [ followed by ] at the start of the line. (I.e. type the square brackets)
It would be awesome to have the ability to pull a summary of ALL ToDo (across whatever scope you define - project, subproject, etc) into a single Note.
I could see the ToDo section becoming an Overview where I have an active (unchecked) list of to do items grouped by project (or #, category, etc) that makes sense for the case.
You should be able to do this:
  1. search for \todo
  2. save as an overview
  3. once saved, change the overview filter option to only show todo items
