What I did: Dragged the note to the top.
What happened: It pinned it, rather than just shifted the order.
What I expected: Just move it to the top. I accidentally selected don’t show again at one point when it asked to pin or move and now it will only pin it. I can’t find the option to show that dialog again.
macOS Catalina: 10.15.2
Agenda: 9.1.2
Indeed, the problem is that you choose to always pin by selecting the “don’t show again” option. To reset the alert, here is what you can do:
- Quit Agenda
- Open the app Terminal, which is in /Applications/Utilities
- Copy this into Terminal, and press return
defaults delete com.momenta.agenda.macos suppressAskToPinNoteAlert
- Start Agenda again, now it should present the dialog again. Let us know if that works.
That worked for me. Thanks for your help.
