UI glitch when opening a collapsed note. See image below.
Thanks, we’ll look into it. Does the console.app log any errors when this happens?
There does not appear to be in any log entries.
If you make a small edit to the note (eg add a space), does the problem correct itself?
It’s turning out to be very hard to replicate. Ill keep trying and if I get it again, I’ll try small edits to see the effect.
