Typing lagged on iPad Pro
What I did: type chinese, english in my note
What happened: keep lagging when typing, screen recording (https://risu.io/5soAm)
What I expected: good flow and smooth typing
Agenda 17.0.2 / iPad Pro 12.9” 2019 (iPadOS 16.3.1)
How large is the table in that note? Does it also happen in notes without tables or short notes?
found it might be triggered by non-latin punctuation, like , and only on iPad OS / iOS, works well when using Macbook.
@mekentosj Just tried to split the note, and the lag issue keep showing, the table size you can refer below
Would it be possible to export that note as an agenda file and email it to alex@agenda.com?
@mekentosj No problem, just sent. Thank you.
Thanks, we’ll take a look
Thanks, hope it would be solved!! :slight_smile:
hello, I have encountered the heavy lag when I type Chinese or any Chinese characters by Bopomofo keyboard. It would not be happened for English …
We’re still investigating this issue, which OS version are you on?
@mekentosj I am using iPad Pro 12.9 / iPadOS 16.6
thank you.
Thanks, we’ll continue taking a look
@mekentosj To update the issue, I realize that typing fullwidth will trigger the lagging on the following text. Guess the reason is : and will trigger emoji.
Thanks for the update, still odd it slows things down this much, we’ll investigate.
Thanks, and hope it will be fixed soon.
