In Agenda on Mac OS, it appears that paragraphs are separated by a single tap on the return key. I’m used to text apps that use two taps on the return key – a blank line between paragraphs. This is a problem when cut-and-pasting from Agenda to another app.
Sure, I could just press the return key twice in Agenda - but then I’m left with a HUGE amount of space between paragraphs.
Is it possible to configure Agenda so that a single return is just a newline, and two returns are a new paragraph, as with most text editors? This is solvable with a simple visual change, changing the spacing that appears when there’s a return between paragraphs. Is there a way to configure this behavior in Agenda?
Simple matter, but this issue makes Agenda unusable for me. Which is a pity, because it otherwise seems like a very nice app.
