When printing a note with even a moderately long title and a date assigned, the title is cut off with an ellipsis and the calendar information on the right takes up the remainder of the line. An option when printing to display the full title would be great.
Good point. Noted.
You might find that if you export a RTF file, and print that, it works better, at least for that particular case.
I would like to see this fixed, also for PDF export.
This should be improved in the next (v11) update.
