Thank you for the great task management app.
I think being able to see what agendas are comming in the near future makes would be great.
Could you consider adding that kind of feature?
Thank you.
Thank you.
You can already do this yourself with a saved search. Just do a search using the calendar control to the left of the search field. Put in tomorrow’s date and Search All Projects. Now save the search and call it “Tomorrow”. (Saved searches require premium features.)
Thank you very much!
