Token for tags in the search field
  1. start the search for notes with 3 tags or more
  2. enter the first tag in the search field and then press the space bar
  3. then I continue the input with the second tag and so on.
Every second tag is not converted to a token after pressing the space bar.
Tokens are generated from all tags when the space bar is pressed.
It should then look like this:
Why do I have to press the space bar twice after the first, third etc… to generate a token?
iOS, iPadOS and Agenda: latest version
Hmm, just tested on Mac, and it worked fine.
Is this just happening on iOS for you?
This happens on iOS and iPadOS.
Thanks. I just tested, and see the problem. We will look into it.
