Hi
I notice that ToDos created gets automatically greyed out / auto-complete on the next day.
Note that I use a shortcut to sync ToDo to Apple Reminders.
May I know what could be the issue? or could it be due to the shortcuts?
Hi
When you say ToDo, do you mean a check list item? Or do you mean a reminder (ie the little clock)?
It think perhaps they are grayed out if there is no time set, or something like that. You might try making some in Agenda first, to see what you need, and then adding that in the shortcut.
Yes that’s correct. I was referring to check list item.
The way i did it was I create a checklist and add a reminder at the end of the item.
Is there a better way yo create a reminder from the checklist?
No, that is how you would normally do it.
If it is grayed out, it probably didn’t have a due date or something. Could that be it? Best to play with the reminder settings (click on the clock), and see why it is grayed out.
