I am wondering if there is a certain shortcut (and or functionality) that automatically ticks all to-dos.
I did not keep my todos clean in the past, but would be happy to use the newly introduced to do overview. However, ticking off everything (for the past years) manually, seems like an overkill. Anyone any idea how to achieve this a bit faster?![]()
On the Mac you can select the text, and use Edit > Checklist > Mark All As Checked.
Hope that helps!
Thanks @drewmccormack - not exactly what I was looking for, but it did the trick. Thank you! Quite neat that one does not need to select the text (but only enter the relevant note) and can access it with a shortcut.
