Is there a way to have links created so that through Shorcuts you can make it easy to put them in agenda? A workflow if you will? can you attach the shortcut if anyone made it? i know they made one for Things 3 and Bear.
Don’t know, but I would love to link Notability to Agenda.
Would love to see the Things workflow…
I don’t know if it’s what you want, but I created a shortcut that does the following:
- Input is any selected or shared text.
- Asks you for a title for the Things task (and also some things about due date etc, which could be made optional)
- Creates a Things task with a link to an Agenda note (since we know already what name the note will have).
- Creates the note in Agenda in “Task notes” project.
- Puts a link back to the Things task at the top of the note.
- Pastes the selected text into the note.
It works well enough but I want to make it possible to handle rich text or markup, and to save other files as attachments.
I want it to be able to work similarly to the video
Watch “Bear and Things Screencast” on Vimeo: https://vimeo.com/256888825?ref=em-share
However, with the new update of shortcuts u don’t need to go to the shortcuts app anymore u can just share it to shortcuts. If possible, I was looking to see if I could just have the link copied and attached to an existing event In agenda or be able to create an event.
That sounds interesting, @admkenshin! Would you mind to share the shortcut? I am unable to reproduce it.
Maybe when I’ve cleaned it up a bit, right now it has a lot of specifics related to my job.
However the cornerstone is x-callback-urls. I use Shortcuts’ built in Things task creation, which returns the created task ID. Then I use urls to create a note with the same name in Agenda, and put a link like things:///show?ID=xxxxxxxxxx at the top of the note.
Has anyone been able to create a Shortcut that I can reference? I’m having trouble getting one to work.
Hey! Yea, I created a workflow that works with fantastical. This allows me to use the dates and also the individual tasks from any project and move them to fantastical. I mainly use it for inbox. Since fantastical syncs with my calendars it then syncs with agenda. So all of my events come out in agenda if I make them into events instead of reminder (how I show them in the video). When agenda supports reminders then u will no longer need to make them into events and can just make them into reminders so that they show up in agenda. Nevertheless, fantastical is great for reminders so I don’t use agenda for reminders. Here you go!
Here are the links:
https://1drv.ms/v/s!As-w4l1K5sUCg70M49qz_GTymvJlbw (Video)
Shortcuts (Shortcut)
