Text Filter Feedback
Would be nice to be able to filter notes by unchecked “Marked as done” instead of just a list.
Can you explain this? I don’t fully understand.
At the moment, you can select the “Checked Items” and/or the “Unchecked Items” in the text filter.
Are you perhaps referring to the note level “Marked as Done” in the yellow button at the top? If so, that is not part of the content, it is part of the note. To filter those, use the search field top-right. You can use the “Filter Notes” button to filer out notes that are marked as done, or vice versa.
Hi, thank you for the clear explanation. I did find the not done filter and was able to filter the notes like that. This is what I was looking for! Thank you!!
Glad it worked out! Let us know if we can help with anything.
